Stall Converter Question.....
SPECS:
New 350/290hp GMPP crate engine;
new Holley 670 Street Avenger;
new MSD HEI with new MSD wires and new AC Delco plugs;
Engine's full advance 36* @ 2400 RPM; Initial timing: 18*
Vacuum at Idle (in Park) 15"...in Drive 10" (according to GMPP, this is normal)
Completely checked for vacuum leaks...none found;
Compression check (all 8 cylinders) between 120-125psi each;
At cruising speed: smooth, no backfires, runs strong;
Acceleration from a dead stop: Strong, no hesitations, no bogs;
Changed carbs (thinking maybe it was the carb)...no changes noted.
Only thing I find odd (other than the rough idling) is that for me to get 650 RPM in Drive, I have to set the RPMs @ 1100 in Park.
It currently has the stock transmission (automatic)...do I need to go to get a higher stall converter? Will this solve my idling problems?
A smaller (looser) torque converter will help too.
