1974 Seats Allignment ??
Old Dec 26, 2008 | 04:12 PM
BIGJIM13's Avatar
BIGJIM13
Default 1974 Seats Allignment ??
Hi
we are getting the seats put in out 1974 coup and the bolt holes for the tracks seem to be off!!! the tracks are correct for a 74...
does anyone know if the bolts goes in the inner or out hole on the track closest to the console?
Old Dec 26, 2008 | 04:34 PM
tfi racing's Avatar
tfi racing
Mine use the outer holes,the double hole ends of the tracks are at the back of my seats,hope that helps...
Old Dec 26, 2008 | 04:44 PM
BIGJIM13's Avatar
BIGJIM13
Thanks what side are the adjusters on?
Old Dec 26, 2008 | 05:54 PM
Paul L's Avatar
Paul L
I don't wish to seem rude but they just plunk down and bolt in!
Old Dec 30, 2008 | 11:40 AM
BIGJIM13's Avatar
BIGJIM13
but that does not seem to be the case with me...
is the pic you show a right or a left?
Thanks for the comments
Old Dec 30, 2008 | 12:08 PM
mapman's Avatar
mapman
Originally Posted by BIGJIM13
Edit Corrected: "The bottom of paul 74's seat has the seatbelt interlock wiring so it is the driver's side." Correct: Seats are identical, no left or right.
I believe the interlock was exclusive to the 1974.
The seats should swap driver's to passenger's side with no problem.
You might want to do a search on defeating the 1974 interlock.
Old Dec 30, 2008 | 12:28 PM
Paul L's Avatar
Paul L
Actually the seats are identical; there is no left or right. Note the chrome adjuster is always on the one side. And the interlock sensor is on both. If you had a very heavy package on the passenger seat in 1974 the car would not start unless you buckled it up!
Having said that, mine do have a left and a right now because I chose to install the optional pass-through shoulder belts.
Old Dec 30, 2008 | 02:13 PM
BIGJIM13's Avatar
BIGJIM13
Ok
Thanks the seats I have are correct according to Paul 74 pic - ***** on the inside drivers and outside passenger..problem is the track for the passenger side inside holes do not line up ...all the parts are correct and there is only one set of holes ...that is why this is perplexing!
Old Dec 30, 2008 | 02:55 PM
Paul L's Avatar
Paul L
I can only conclude at this point that you have the wrong tracks.
Old Dec 30, 2008 | 04:12 PM
BIGJIM13's Avatar
BIGJIM13
Paul
actually just got them pushed in - thanks
hey since you are a 74 also ...the rear grills above the luggage rack..are they held in place by regular screws or do they use those gromets with the nut in them
Old Dec 30, 2008 | 10:32 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I believe the seat switch attached to springs in the 3rd photo goes on the passenger's side. The driver is assumed; the switch is used on passenger side tells the car whether or not the car is carrying a passenger then decides if the seat belt is unloaded.
Also in the same photo, you'll notice a tear in seat cover. That's likely from scraping over the seat belt assembly. Make sure threre's no carpet between the SB assy and the floorboard or the assy will sit too high ruin your seat covers when you adjust the seat(s).
Also, the seats are not interchangeable, left and right. Don't forget about the shoulder belt which goes through the back of the seat.
FWIW
Old Dec 31, 2008 | 09:12 AM
Paul L's Avatar
Paul L
Paul
My car is in storage but if I remember correctly those are Phillips head screws used with speed nuts.
Old Dec 31, 2008 | 09:33 AM
Paul L's Avatar
Paul L
FWIW
Yes and no. In the absence of the shoulder hardware the seat frames are identical. Only when the pass-through belts are added do you create a left and right. Of 5,474 convertibles produced in 1974 only 618 were ordered with the shoulder belts.
Old Dec 31, 2008 | 10:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...the rear grills above the luggage rack..are they held in place by regular screws or do they use those gromets with the nut in them...
Trim screws. You'll see them.
BIG: purchase the 74 assembly instruction manual (AIM). It'll be a big help on your car and will soon pay for itself.
Old Dec 31, 2008 | 11:58 AM
73, Dark Blue 454
Correct Paul 74. The seat frames and hardware are the same, L to R. Once the seats are assembled and upholstered, then obviously they are no longer interchangable.
To 1974 Seats Allignment ??
