400 stroker 327 block
Old Dec 26, 2008 | 10:38 PM
darsondriss's Avatar
darsondriss
Default 400 stroker 327 block
hey guys i dont have alot of info on this stuff (got a little import myself) but im posting this for my dads 68 vette. Hes got a 327 block and currently has the 400 crank in it. He ran into some problems on the install of it originally becuz the new crank is external balance. He reused the stock flywheel with some balance adaptor plate that he had to beat the crap out of to get it to fit in there and couldnt get the access plate back in right.
Well just recently his clutch has been slipping/rattling alot and we decided to go in and replace it. I think the slipping is probably a result of using a cheap autozone clutch but while we were in there we decided its probably about time to fix the flywheel. Well he got on ebay and bought a nice centerforce clutch and a flywheel and we tore it down. We put the flywheel, clutch, and pressure plate on and found that the flywheel was too big to fit in the bellhousing.
what does he need to get to get this car back together again?
Old Dec 26, 2008 | 10:51 PM
MikeNKalibs6t7Coupe's Avatar
MikeNKalibs6t7Coupe
Looks like either a different bell or different flywheel / clutch combo, if the clutch has been installed already then return is not a viable option. Then you are looking at a different bellhousing, my money would be spent on a blow proof bell from lakewood or similar company, that way in the event of clutch failure you get to keep your legs and feet hooked together. My 2 cents good luck
Old Dec 26, 2008 | 10:58 PM
darsondriss
ya the problem is going to be convincing my dad to spend money on something The clutch fits in there fine its just getting it over the flywheel, but like i said i dont know much about the measurements of these engines, so idk if someone knew the size of the right flywheel and whatnot.
But ya as you said i would imagine just buying a bigger/better bellhousing would be the smartest idea but idk.
Old Dec 27, 2008 | 12:38 AM
vettesbydesign's Avatar
vettesbydesign
68s ran a 10.4 clutch/flywheel,and you probably got the 11 inch.Either,get a scattershield,or a 11 inch bellhousing.I sale repop #621 bellhousing cheaper than you will find anywhere else.I also,sale Mcleod scattershields,and SFIs.
Old Dec 27, 2008 | 01:31 AM
FRSTR90's Avatar
FRSTR90
Ditch the bellhousing and don't even think about using one!!! A scattershield is the only way to go... My father knew a guy who had a '68 nova with a pretty stout small block. He power shifted at 7500 on stock clutch assembly and bellhousing, and the clutch exploded. The guy lost his right leg, broke his left leg, and destroyed the car.. My dad also built a cast iron headed L88 for his 68' chevelle. He blew what I think was a Hays clutch. Luckily, he had a scattershield. The clutch distorted the scatterschield so much that it actually dented the floor pan and hit his foot. My dad still walks with both legs today. I just don't see the point on taking a chance.
To 400 stroker 327 block
