jets sizes?
Old Dec 31, 2008 | 02:38 PM
  #41
noonie's Avatar
noonie
Originally Posted by v2racing
Good read and it is right on. Norval has done his homework and it pays off. Unfortunately, not to insult anyone, but I think it is beyond most enthusiast skills.
You should really contact him and get links to his step by step testing.
He may have posted it elsewhere too. It was very detailed.
In fact, so much so, that anyone with a wideband could probably tackle it.
I did that with an old dp holley 4011, that no one likes, years ago, but without the wideband and it really paid off. Had to r&r it over 30 times to dial it in. Then it ran on a dd for over 10 years with no probs.
It can be a lot of work.
Old Dec 31, 2008 | 02:43 PM
  #42
gkull's Avatar
gkull
Get ride of the 3/8th PVC line and plug off that big hole inducing a vacuum leak and rerun you test with no other changes.
Then read this and consider the up one jet size primary or up the primary high speed dia.
IMO - if it takes 10 seconds to clear out the extra fuel from a WOT squirt you are inducing way to much gas. I drilled out my squirters .003 -.004 to give a bigger instant shot on the primary and left the 30cc.
http://www.carcraft.com/techarticles...eds/index.html
Old Dec 31, 2008 | 02:44 PM
  #43
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
The idle problem is not uncommon with low vacuum motors. You may have your throttle blades open far enough that you are into the crossover circuit (cruise) which is beyond the idle circuit. You may need to drill holes in your throttle blades as gkull mentioned was done to his. Mine also had to have this done to it for my 406.
Set your idle mixture in gear as this is where you drive the car, unless you are putting it in neutral every time you stop.
To get your cruise rpm a little richer I would try going up one jet on the primaries and going down one on the secondaries to compensate for the wide open throttle.
It is odd you need such a large accelerator pump, 50cc, on the front. Are you adjusting it properly. I would also double check your ignition timing. If it does not have enough initial lead and is retarded in the lower rpm's it will cause a stumble. You may need to limit the total advance of the distributor so you can set the initial higher. You may also need to put lighter springs in to come onto the advance earlier.
Use a timing light and tach to check your initial timing and map out the timing through the rpm in 500 rpm intervals up to your maximum advance. Also, are you running a vacuum advance and is it adjustable?
What is your cam specs and your compression ratio? What do you have the squish set at? What heads do you have and what size ports and valves do you have? What do you have for an intake manifold? Do you have headers and what do you have behind them for exhaust. What kind of engine temps is you engine running at? All of this ties together. It all needs to match to run properly.
I would like a little more info on the crossover circuit. I know there is one in Webber carbs but didn't know there was a separate crossover circuit in a Holley type carb.
In Webber carbs the idle circuit and crossover inter-connected, meaning the idle jet is responsible for both circuits. Meaning that for cruise up to approx. 2500RPM the carb is working from both circuits.
This is same for Holley type carbs however the transition circuit is the second circuit after the idle circuit. The idle circuit is adjusted by the idle feed restrictions, idle air bleeds, and the idle mixture screws. The transitions circuit come into play when the throttle blades open slightly exposing the transition slots and get fuel through the idle feed restrictors.
At this point the engine is running off both circuits the idle circuit and the transition circuit. Depending upon the size of your engine and the rpm's it is running at, you can have flow from the idle and transition circuits well into the higher rpms.
But lets just say 2500RPM and call it a day as the main circuit will take over after that. But most of us are cruising below 2500RPM, I know I am and therefore the idle mixture screws play an important part in determining your cruise A/F ratio
Old Dec 31, 2008 | 03:00 PM
  #44
v2racing's Avatar
v2racing
Your are correct. I should have said the throttle blade could be open far enough to expose the transition slots at idle. You lose control of your part throttle and idle in this situation. That is why holes are drilled in the throttle blades so that the blades can be closed down below the transition slots and still get enough air to idle a modified motor.
Old Dec 31, 2008 | 03:20 PM
  #45
MotorHead's Avatar
MotorHead
Yes, my Race Demon carb came from the factory with holes already drilled in the throttle plates, I guess they know what type of motor it's going on
Old Dec 31, 2008 | 05:41 PM
  #46
corvettedave383's Avatar
corvettedave383
here's some engine specs
383 forged motor 9.2 comp
BRC 3.750" crank, bcr 5.7 H - beam, bcr 2618 pistons,hd pins
custom machined blower cam(258/646 112lsa)
custom roller lifters solid
T & D - shaft rockers 1.6 ratio
dart pro 1 platinum alum 215 heads
Weiand - team G Intake Manifold - single plain ( 2800-7200 RPM Range)
quickfuel(holley) 750cfm double pumper, mech sec
vac level at idle = 7 to 8 hg
th350, 2200 stall
throttle blades - arent opened too much asfar as I can see
50cc pump - I had quite a bad off idle stumble, the 50cc pump and bigger shooters(37 at present) was the only thing that has come close to fixing it, and sometimes it feels as I can still feel a small amount of it still there
Timing - intial is 21 degrees and total is 35 degrees and all in by 3000 rpm, no vac advance
headers yes, no cats, straight throw to magaflow back box's
engine temps - a steady 180 to 190
squish set at? = not sure what you mean?
hope this info helps
cheers
dave
Old Dec 31, 2008 | 05:44 PM
  #47
corvettedave383
Originally Posted by noonie
You must go beyond basic jetting.
Here is a link to a guy that did extensive testing with some surprising results, like 20 mpg with a supercharged 540. He seemed to get it perfect throughout the whole rpm range.
His research is very detailed, so either search for more results or pm/email him. Nice guy, sure he would be glad to help.
http://forums.corvetteforum.com/c3-t...fer-ports.html
Thanks for that info
Old Dec 31, 2008 | 05:48 PM
  #48
corvettedave383
Originally Posted by C3BB4SPD
Dave,
When you say 'big blower cam'... ...how big? And which transmission? What is your timing (...intial and total) set at? The reason I ask is that's not much converter, with a fairly tall gear. And you can't look at one piece of the puzzle without considering all the other peices. Also, has the off-idle stumble been completely resolved? If not, and you're running a bunch of camshaft, you might be fighting a battle you can't win with your current gearing.
You've been given sum really good info so far, and I agree with most everything that's been said. However, in my opinion, tuning the way you're doing it (with the O2 sensor...in real world conditions) will ultimately provide better results than on the dyno. There's been plenty of money spent to have engines and/or cars 'dialed-in' on the dyno, only to have them run like crap on the track. Not to say dyno's don't have their place, just that sometimes they don't paint a complete picture.
A specific example: My '69 Camaro was running 10.60's in the 1/4 mile and having a fuel problem at the top end, so I decided to put it on a rear wheel dyno to sort it out. The tuner's recommendation included re-jetting (optimized), which we did. Back on the track the car slowed (consistently) to the high 10.70's. I went back to the original (pre-dyno) jetting and it went right back to the low 10.60's. (The problem ended up being a fuel pump relay chattering...which we couldn't get to replicate on the dyno either, so a complete waste of time and money.)
My point is, you've taken solid logical steps and done good work so far.
Just keep after it...and good luck!
...Jerry
thanks mate, see my other post for more info
cheers
dave
Old Dec 31, 2008 | 05:53 PM
  #49
corvettedave383
what pvc line?
the 10 sec thing is at the start of a steady throttle cruise
cheers
dave
Old Dec 31, 2008 | 05:55 PM
  #50
corvettedave383
at part of throttle blades do you drill?
cheers
dave
Old Dec 31, 2008 | 06:31 PM
  #51
v2racing's Avatar
v2racing
Squish is how close your piston comes to the head at top dead center. The closer it comes to the heads flat area, the quench area, the more efficient your combustion will be, especially at low rpm's. To make use of squish you need to be .040" at the widest.
That is a pretty big cam for a 383 with only 9.2 to 1 compression. The ports are pretty good size and you have a single plane intake. All of this makes for an engine that would be somewhat weak in the bottom and more setup for high rpm. No vacuum advance is not helping street drivability either.
C3BB4SPD was correct in his assumption about having to much cam and not enough stall in your converter. Your gearing is pretty steep for that engine combo also.
I hate to say it, but you may not be able to tune your way out of this one.
What do you want this engine to do. Do you want good street manners with good bottom and mid range power or do you want a drag race engine?
Old Dec 31, 2008 | 06:55 PM
  #52
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Your combination is too varied for good engine response. For a CR of 9.2:1, you should be running a dual plane manifold and a cam with a duration of 230 to 235 and a lobe separation angle of ~110.
Your initial timing is too much - it's not surprising to have a stumble off idle. Vacuum advance will help a lot for smooth running - try about 15 degrees of vac adv, and an initial setting of ~15 degrees. When you hit the throttle, the vac advance comes out and the motor should pull more smoothly with your initial setting of 15 degrees. Try it!
Old Dec 31, 2008 | 07:10 PM
  #53
MotorHead's Avatar
MotorHead
I didn't see this before, you have some serious mismatched parts going on unless you were planning on putting a blower on it. Your DCR must be in the 6:1-7:1 range which is not good. You may still get it running OK with some tinkering but it is going to be lazy in the lower RPM's
Old Dec 31, 2008 | 07:12 PM
  #54
larrywalk's Avatar
larrywalk
I'm not trying to start a spat here, so forgive if it came off that way.
I will say that most of these vehicles I have tuned were used in real world use, not just on the dyno. This is not counting all the racing. I also tune my own cars on the road with DTT's WegoII.
All of the latest crop of performance cars and bikes run withing these AFR settings. 14.7 is the cruise AFR on almost every vehicle made in the world. ZR1, ZO6, Hyabusa Suzuki, the 650 HP 750 Tq V12 Twin Turbo Mercedes, it doesn't matter. They all have to be at this AFR at cruise to pass emissions. They all are very high horsepower and run very well.
Having said that there are times that combinations can show richer AFR's than they are actually at because of over scavenging at overlap.
V2, I agree - 14.7 is best. I guess that my 406 must be a mystical Gen 1 that runs great at stoichiometric at cruise! However, when I add throttle and the vacuum drops below 10 inches of Hg, the power piston rises, and further, the large Quadrajet secondaries start to open, dropping the A/F ratio to high 12s. I have had similar results with Holley 750 and 800 DPs, selecting 8.5 power valves for enrichment, but my tuned 800 Q-jet remains the best and most consistent, running 0.04 sec quicker in the 1/4 at 11.96!
Old Dec 31, 2008 | 07:49 PM
  #55
MotorHead's Avatar
MotorHead
What is generally understood on the tuning forums is you tune the motor for what the motor likes not what you think it likes. If it runs fine at the magical 14.7 then that's fine, mine doesn't and many others don't either. It is not necessary to make your motor run at 14.7:1 A/f if it doesn't run well there.
I spent 2 years trying to get past just changing jets and squirters so my carb runs good at idle and cruise and WOT. Searching the internet and speed shops for someone that actually knew how tune a carb was no small job. People that know how to tune a carb past changing jets are getting harder and harder to find every day as most are passing on.
I finally found one guy who forgot more about carbs than most will ever know. He helped me solve a problem with my carb going lean at WOT that no one could figure out. I am very grateful I met this fellow.
These are the things I had to do to out of the box 825 Demon carb to get it to run properly and while I am not at the magical 14.7:1 A/F I still managed to get 24mpg on the highway with my previous 550HP 406ci.
I had to buy an assortment of blank air bleeds and pin drills to change the air bleeds.
Primary jets: 74
Secondary : 82
High speed air bleed : .026", a long way from stock .039"
Idle air bleed : .070"
Idle feed restrictor .031"
Power valve channel restrictors : .063"
Squirters: 35
Old Dec 31, 2008 | 07:57 PM
  #56
corvettedave383
the engine has been built for blower or turbo, which I will do that part next year, just trying to get it to run happy till then, It would be nice to be very fast, but nice to drive, could be a problem maybe?
what about fuel injection?, would that help to solve some of these issues?
cheers
dave
Old Dec 31, 2008 | 08:01 PM
  #57
corvettedave383
the engine been built for blower/turbo
timing - there a interesting problem, I have changed the bushes in the dizzy, to give me a longer timing curve, to try get the intial timing as low as possible, 21 is as low as it will go, once ive set 35 total, I thought they say big cams need more intial timing?
cheers
dave
To jets sizes?
Old Dec 31, 2008 | 08:04 PM
  #58
corvettedave383
yeah blower/turbo in near future, yeah the engine does feel lazy at low rpms, but once it hits 3000+ , it really starts to shift!
cheers
dave
Old Jan 1, 2009 | 08:20 AM
  #59
gkull's Avatar
gkull
cheers
dave
258 degrees of solid roller is more than I use in my 434 ci. How did you determine installing it?
Your up into racing motor cam timing. It can be made to run, but not smooth.
You did say no PVC line to the carb?
I use a 4 hole wood thermal spacer which also increases the vacuum signal to the carb on my single plane. It helps when you are on and off the gas.
Old Jan 1, 2009 | 12:58 PM
  #60
corvettedave383
the engine was custom built for me, and parts choosen to support 800hp+, using blower or turbo's, which will be looked at once the pound to dollar has improved
what do you mean by pvc line?, fuel line?, pcv line??
the spacer sounds like a good idea, I will try get something like that
cheers
dave
