jets sizes?
Old Dec 28, 2008 | 06:08 PM
corvettedave383's Avatar
corvettedave383
Default jets sizes?
Holley double pumper 750cfm
do the secondarys jets need to be bigger than the primaries by so many sizes??
do the jets need to stay with in a size range to each other?
is it ok to have the primaries jets bigger than the secondarys?
thanks
dave
Old Dec 28, 2008 | 06:47 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Rule of thumb is 6-8 sizes bigger in secondary with a power valve in the primary metering block
Old Dec 29, 2008 | 09:00 AM
dmaaero's Avatar
dmaaero
All depends on the engine, my rear jets are smaller than my fronts. Guy at the dyno shop said he had seen it before, but it wasent very common. 750 DP with only 1 power valve.
Old Dec 29, 2008 | 11:15 AM
gkull's Avatar
gkull
Please explain to me how this could possibly work?
to the poster. the only way to really setup a carb is on an engine dyno with all the sniffers and inputs. On the primary you want to run as lean as possible and the secondary right at the max rich A/F for the most power. My Demon achived this with a spread of 10 jet sizes from front to back.
without a dyno. lean the primary jets down 2 numbers at a time till it runs ruff and kind of surges at a steady state cruise down a level highway at 60 -65 mph. Then back up 1-2 jet sizes to where it runs nice again. Check the plugs for a white- light tan color. Secondary is best done with a chase car. be talking on the cell phone and floor it to WOT in top gear. the chase car should see an initial blast of black smoke from the squirters and then nothing. Black should go away and no smoke at all
Old Dec 29, 2008 | 12:16 PM
corvettedave383
thats interesting
Old Dec 29, 2008 | 12:34 PM
corvettedave383
I have a o2 sensor installed and the inovate box plugged into a laptop, I can record live date driving along the road, which I would have thought would be better than a rolling road, your getting real airflow, etc
what do you mean by as lean as possible on the primary jets?, what exact level 12.5 or leaner??
when accerating Iam running at 14 to 15 on the primarys, then when I get into the secondary's it goes down to 11's
Iam at 70 front and 82 back at present, ive got a 383, big blower cam, tight convertor 2200 stall and high diff 308, I did have a off idle stumble, solved with bigger primary shooters and 50cc accerator kit
let me what you think?
cheers
dave
Old Dec 29, 2008 | 12:58 PM
gkull's Avatar
gkull
You want 14.5 - 15 on a steady state cruise an a low of about 12 for max power at WOT. sub 12 would be blowing black smoke and a loss of power
Old Dec 29, 2008 | 01:56 PM
dmaaero's Avatar
dmaaero
I doubt i can explane how it works, I"d be more than happy to talk about it though. So far everyone i have told this to is puzzled how it works. Most people say: how can you be riding around on large jets in the front all the time, makes no sence at all!!! Here"s a question for you to think about, lets say we have 70 jets in front and rear. When you make a dyno pull the engine goes lean first half of the pull, then on the second half of the pull it goes rich. What you going to do? What we did was increase the jet size in the front (to stop it from going lean) then we decreased the jet size in the rear (to stop it from going rich)
Old Dec 29, 2008 | 02:09 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Before you attempt to tune your carb, put it into the stock configuration and try that first...
http://www.holley.com/data/TechServi...%20Listing.pdf
If you have any way to measure your air-to-fuel ratios, cruise should be about 14 or 15:1, and full throttle should be 12.5 or 13.0:1.
Old Dec 29, 2008 | 02:12 PM
larrywalk's Avatar
larrywalk
cheers
dave
Are you running a blower, or just a wide lobe separation angle?
Old Dec 29, 2008 | 02:16 PM
larrywalk's Avatar
larrywalk
If you're not running a blower, I'd recommend 35 shooters. If that doesn't help, go to 72 primary jets, and further to 74 primary jets. On the secondary side, I'd cut back to 78 right away.
Old Dec 29, 2008 | 02:21 PM
corvettedave383
so when ive got my foot to the floor, it should be 12.5 at all parts of the rev range??
cheers
dave
Old Dec 29, 2008 | 02:22 PM
corvettedave383
makes sense, when you put it like that
dave
Old Dec 29, 2008 | 02:24 PM
corvettedave383
no blower at present, 112 for lobe
dave
Old Dec 29, 2008 | 02:25 PM
corvettedave383
I will give that go, and report back with afr levels
cheers
dave
Old Dec 29, 2008 | 03:49 PM
gkull's Avatar
gkull
The problem you would have to have to make a carb do this is the Wrong dia air bleeds and or plugged power valve.
The primary cuircut gets fuel from the idle cuircut/power valve, and primary jets. that is why the primary used much small jets than the secondary. It has three fuel sources to make the 14-15 A/F ratio.
Your secondary has an idle curcuit if you have the 4 corner idle screws, but the butterflies don't open until you start to floor the car and you want a richer 12 ish fuel ratio to make max power.
When you make a dyno pull the engine goes lean first half of the pull, then on the second half of the pull it goes rich. What you going to do? what you do is find a competant carburator shop and have them set up the air bleeds for the correct flow to the boosters. Your boosters are not flowing enough air at lower rpm to pull the fuel out. I would increase the primary air bleed diameter and go down on the jetting. another fix is the booster type/size. In an overcarbed setup annular boosters work. I kind of like down leg style
Old Dec 29, 2008 | 03:53 PM
gkull's Avatar
gkull
cheers
dave
Right around 12 when floored. You have to adjust the squirters to add fuel at the tinnest movement of the throttle
To jets sizes?
Old Dec 29, 2008 | 04:42 PM
dmaaero's Avatar
dmaaero
My carb does not have adjustable air bleeds, it does only have 1 power valve so the rear is plugged.
Does this have anything to do with low engine vacume? or is it strictly caused by to small of air bleeds......
Old Dec 29, 2008 | 05:56 PM
gkull's Avatar
gkull
The air bleeds are not adjustable they are little brass incerts.
the booster flows fuel depending on how much air is rushing by it. You can look in the carb and see the booster. Just open the throttle to 4000 rpm and the booster will look like it is just spraying gas into the air stream. The air bleed diameter and the jet fuel flow determine the amount of fuel that the booster can feed into the fuel stream. which sets your A/F ratio
The type of booster it's self determines at what air flow it workd the best. Like I said annular for over carbed and big cammed engine that have lots of low rpm reversion.
second is the down leg booster. Closer to the butterflies to get the faster air speed.
Straight leg. I would only use them on a higher air flow dual plane equiped motor. Like 400+ ci
Old Dec 30, 2008 | 07:45 AM
gkull's Avatar
gkull
Dave, I would try to keep the primaries 8-10 jet sizes smaller than the secondaries. I increased the diameter of my high speed air bleeds and was able to run smaller jets without getting lean popping.
Out of the box double pumpers tend to have too rich at idle. I have drilled my throttle plates with a .110 drill bit. Lots of articles on idle feed restriction methods
http://www.chevyhiperformance.com/te...ics/index.html
