View Poll Results: how would you purchase a rotating assembly?
entire kit
33
64.71%
piece it out.
18
35.29%
Multiple Choice Poll. Voters: 51. You may not vote on this poll
Poll on Rotating assemblies.
Old Jan 2, 2009 | 05:17 AM
L79racer's Avatar
L79racer
eagle esp rotating assembly
Old Jan 2, 2009 | 10:59 AM
GDaina's Avatar
GDaina
I had a choice, buy a 502 short block or go piece meal...I went piece meal...
advantages to me:
bought an eagle internal weight, 4.25" crank...gained 29 cubes and saved $$$ on the price of external balancer and flywheel....used my exiting gear
Bought JE 10.5 pistons.....gained compression
Bought Trick Flow H beam rods w/ARP bolts.....lighter than factory rods
Bought solid roller cam...higher lift, longer duration...more zooooom zoooooom......
Had machine shop finish hone the block, balance the rotating assembly
When all was done, it cost me just a shade over 500.00 more to go peace meal than buy a short block...
Old Jan 2, 2009 | 11:42 AM
sly vette's Avatar
sly vette
I will be following the same path!
Thanks,
Sly
Old Jan 3, 2009 | 12:02 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I pieced mine. AMS lightweight 4340 forged crank. (Eagle forging), Callies compstar lightweight H beam rods, Mahle Lightweight low expansion forged Pistons. Fidenza Lightweight flywheel. Revs Quick
Old Jan 3, 2009 | 12:48 AM
sly vette's Avatar
sly vette
I will be going the same way. Got a lot of great suggestions and referrals!!!
This site Rocks, and thanks to all the respected members that participated in this post.
I will keep you in touch as this build progresses.
Sly
Old Jan 3, 2009 | 09:09 AM
BLOCKMAN's Avatar
BLOCKMAN
We have been using the Callies Compstar cranks in out 383 builds as they are second to none as far as sizing, staightness, indexing and for around 600 dollars.
Rods we either use the Callies Compstar 6 inch rods are about 525.00 a set or the Scat I beams with the 7/16 bolts are about 315.00 a set.
Pistons we have been using the Maule pistons and ring kits and they are about 525.00 for the kit.
Balancing is 175.00 and on the rods we size them on both ends and check the pin bores in the pistons for proper clearance.
On the cheaper cast cranks we have seen the indxing off but there only a 200 dollar crank what do you want!!
Old Jan 4, 2009 | 01:51 PM
sly vette's Avatar
sly vette
I take it the Callies Compstar is a Cast steel Crank???
Old Jan 4, 2009 | 02:32 PM
BLOCKMAN's Avatar
BLOCKMAN
The Callies Compstar cranks are forged as Callies don't sell cast cranks and at our shop we don't use cast cranks in our builds
Old Jan 4, 2009 | 10:55 PM
sly vette's Avatar
sly vette
Thats a good price...Is that a wholesale price or retail???
Old Jan 5, 2009 | 12:57 AM
BLOCKMAN's Avatar
BLOCKMAN
Thats what we sell them for as I think there was a small increase since the begining of the year.
Hell I can buy 4340 cranks for 375 dollars but the qaulity is just not there as far as sizing, straightness and indexing. I spend the extra money and do right he first time.
Old Jan 5, 2009 | 01:42 AM
sly vette's Avatar
sly vette
Originally Posted by blockman
thats what we sell them for as i think there was a small increase since the begining of the year.
Hell i can buy 4340 cranks for 375 dollars but the qaulity is just not there as far as sizing, straightness and indexing. I spend the extra money and do right he first time.
me too!!!
