I have all of the vacume lines exposed and am attempting to get things to work porperly. The issue: the vacume diaphgram that opens the defroster door has two nipples - one on the top and one on the bottom. the assembly manual only shows an attachment for one vacume hose on the top. If I follow the diagram in the book, I have no place to connect the bottom vacume line -- any ideas?
I'm confused...do you have an extra vac hose or an extra nipple?
Bottom line on the dash control are numbers.#3 goes to the defrost,#4 goes to the AC air valve which is right under the defrost,#5 goes to a T that goes to the recirc door and the outside air valve#1 goes to a T that goes to the engine source vacuum and inside water shutoff switch#2 is blank
The defroster diaphragm has 2 nipples on it...one at the top and one at the bottom. on page 134 (sheet 63.5) of the AIM it explains how to route the defroster hoses. My car has A/C which reflects the digrams on page 133, showing a single vacume hose to the defroster valve. I am begininning to think that someone before me replaced the valve (with the wrong one). everyithing else on the car is correct.
