tricked out exhaust
Old Dec 29, 2008 | 11:27 AM
pointy1's Avatar
pointy1
Default tricked out exhaust
done the searches, can't find an answer.
want to order a mast motorsports ls3(600hp) for my 1970.
can't run sidepipes without heavy modification to the pipes themselves.
can't run 2 1/2" exhaust ( too restrictive )
is there a block hugger header that will exit to the side so that you can hook up a 3 or 4" side pipe, and then utilize a factory cover?
i will be changing to a steeroids or vbp rack and pinion so clearance for the headers shouldn't be a problem.
once i get the exhaust hooked up, how will the engine react to sidepipes without an o2 sensor? or do i have to hook that up?
thankyou for the help.
Old Dec 29, 2008 | 04:43 PM
GDaina's Avatar
GDaina
A company makes headers to fit factory side exhaust...is that what you are looking for?
Old Dec 29, 2008 | 05:32 PM
pointy1's Avatar
pointy1
yes, but will the headers bolt up to an ls3?
Old Dec 29, 2008 | 07:07 PM
72LS1Vette's Avatar
72LS1Vette
You might want to check the LSX swap thread sticky at the top of the page for some exhaust ideas. Some people have used Hooker sidemounts but they do require modification of the headers. Not an insurmountable task and probably less expensive than having custom headers fabricated. One of the guys (maybe SpeedHound?) has a header set available that you could probably connect to a custom sidepipe. I don't think you wil find a commercially available solution because there isn't enoough demand to attract the big vendors.
Rick B.
Old Dec 29, 2008 | 07:25 PM
OzzyTom's Avatar
OzzyTom
I doubt there would be a set of headers off the shelf which would perfectly fit for your intended application.... LS3 in a C3 with original side pipes.
You'll have to bite the bullet and get a set of custom pipes bent... or possibly modify, as mentioned, a set of LS3 headers.
But do it after you have installed everything else. (steeroids A/C etc)
You don't want to find any issues with clearances later.
I assume you are running FI with an ECU.
O2 sensor is used to provide closed loop feedback for proper fuel mixture control with ECU.
O2 sensor only requires a threaded bung welded in the collectors. Easy to do. Once again, need to ensure bung is placed in position which doesn't place O2 sensor (when screwed in) in harms way, or fouls on body or chassis rails etc.
Old Dec 29, 2008 | 08:25 PM
pointy1's Avatar
pointy1
okay, thanks.
To tricked out exhaust
