I'm going to change the filter on my transmision and would like to know what type of gasket sealer to use. I haven't seen anything posted on this yet and have been checking for quite a while. Thanks in advance for any answers. I can't get over all of the information available on this site.
youll get mixed results but the way to install it is dry. usually you hand tigthen them but i think from reading here that the tourq specs are 13-15 lbs dont over tighten them that will warp the pan and you will be starting all over again.
At the very most use 3 or four small dabs of 3M weatherstrip adhesive to hold the gasket in place on the trans before you install the pan. Otherwise, just lift the pan up into position with a couple bolts thru the gasket. Make sure the pan rails are absolutely FLAT and everything is CLEAN before you put it back together.
I would use a few blobs of grease before I used any sealer on a transmission pan. If you use a GM filter kit the gasket is flat instead of folded, I recommend that. You don't need any sealer then.
