How to get radiator out?
Old Dec 29, 2008 | 06:37 PM
Ronaldo's Avatar
Ronaldo
Default How to get radiator out?
What is the easiest way to get the radiator in a 1968 Corvette with A/C out?
Are there space enough to pull the radiator shroud back and pull the radiator up without loosen the radiator support?
Old Dec 29, 2008 | 06:47 PM
BigBlockTank's Avatar
BigBlockTank
Pull hoses, fan & clutch, fan shroud, and top radiator mounts. It "should" come out. Am I being to obvious not tell you to drain the radiator first?
Old Dec 29, 2008 | 06:55 PM
682XLR8's Avatar
682XLR8
You have the steel shroud like I have. Remove the bolts holding the shroud in place, top and bottom, and slide it back. Remove the bracket on top of the rad, and it should come right out
You installing a new rad, or cleaning the one you have?
Old Dec 29, 2008 | 07:02 PM
BigBlockTank
My bad, you have a small block, tons of room under the hood.
Don't forget hoses, trans cooler lines
Old Dec 29, 2008 | 07:10 PM
Ronaldo's Avatar
Ronaldo
Nope that I did figure out
Depends on the condition on the old one. Its leaking very little. I would like to have it refurbished. It looks like a harrison
Thanks both of you
To How to get radiator out?
