HELP! Half Shaft Ujoint problem
Old Dec 29, 2008 | 08:31 PM
kvetty's Avatar
kvetty
6th Gear
Default HELP! Half Shaft Ujoint problem
I was all set to replace the half shaft joints on my 80 when I hit a road block 2 minutes into getting under the car. The bolts are not hex heads, but almost a star pattern...but not really a star. more like ridges all around the head of the bolt. Has anyone seen these? Is there a special tool to get them off? I was going to post a pic but can't figure out how.
Old Dec 29, 2008 | 08:32 PM
MikeC's Avatar
MikeC
12 point socket or a closed end of a wrench should do the trick.
Old Dec 29, 2008 | 08:36 PM
mapman's Avatar
mapman
When you go to replace them, Van Steel sells the hex head version.
Old Dec 29, 2008 | 09:16 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Those are Torx heads. An E10 socket fits.
Old Dec 31, 2008 | 11:02 AM
kvetty's Avatar
kvetty
6th Gear
Thanks, I am off to Sears to buy a set of Torx and will definately change these to Hex heads.
Old Dec 31, 2008 | 11:09 AM
Vette79C3's Avatar
Vette79C3
Now the Torx you just bought from Sears are obsolete.....lol.
To HELP! Half Shaft Ujoint problem
