Veifying dead cylinders
Old Dec 30, 2008 | 05:17 PM
Oldguard 7's Avatar
Oldguard 7
Default Veifying dead cylinders
Outside of a compression test or a leak down test. Is it safe to remove a spark plug wire from the dizzy tower to "kill" a cylinder. I have a poor idle and am wondering if I'm running on all cylinders. I'm I correct to assume that the idle will change once a plug wire is removed from the dizzy tower and if the idle does not change, the cylinder is dead?
Old Dec 30, 2008 | 05:27 PM
jakesindy's Avatar
jakesindy
Originally Posted by Oldguard 7
Outside of a compression test or a leak down test. Is it safe to remove a spark plug wire from the dizzy tower to "kill" a cylinder. I have a poor idle and am wondering if I'm running on all cylinders. I'm I correct to assume assuming the idle will change once a plug wire is removed from the dizzy tower and if the idle does not change, the cylinder is dead?
You are correct
Old Dec 30, 2008 | 07:09 PM
mrvette's Avatar
mrvette
YES, you are correct, just like above....NOW here is the funny part.....
LONG long time ago in a land far far away, a old friend did just that....and the spark knocked him backwards into the bushes....
so what does he do?? get up and try it again.....same result....
I guess he was not used to being bit but good.....
true story......
Old Dec 30, 2008 | 07:27 PM
Dream Ride's Avatar
Dream Ride
St. Jude Donor '09
Take a test light and ground the clip end. Take the pointed end and poke it into the top of the wire on the distributor cap. If it's not firing there wont be a draw down. If it is firing you'll see a big difference and not get knocked on your best intentions.
Old Dec 30, 2008 | 08:46 PM
Oldguard 7's Avatar
Oldguard 7
true story......
funny you mentioned that, I had my bones rattled by an HEI unit. It felt like the sensation when you hit your funny bone but the sensation is much longer than that.
Old Dec 30, 2008 | 09:14 PM
Tim_Ko's Avatar
Tim_Ko
I've got a 6 cylinder MC. Same problem; it runs badly ... why? How do you differentiate between running and non running cylinders. I ran the bike up to temperature, turned it off, got an infared thermometer and "shot" the exhaust pipes. It's immediately apparent which ones aren't firing. They have digital readouts and you don't have to move from wire to wire. I never tried it on a cast iron exhaust manifold but it should work on a header.
Old Dec 30, 2008 | 09:30 PM
...Roger...'s Avatar
...Roger...
If you have a infrared temp gun you can shoot the exhaust manifold.With headers it really works good but still works with the cast iron manifolds also just not quite as good.
edit -oops didnt see the above post.
Old Dec 30, 2008 | 09:33 PM
wills670's Avatar
wills670
it will work and you will see a change in idle if you pull one that is working.
Big tip: take a wire and attach it to the pliers and the other to a good ground and make sure it won't come off. If you do this the electric current will go to ground and not you.
To Veifying dead cylinders
