81 automatic door locks
Old Jan 2, 2009 | 03:44 PM
Karl24's Avatar
Karl24
Cruising
Default 81 automatic door locks
how do you fix them? Passenger door will unlock sometimes. Otherwise you have to do it manualy. Is the automatic door locks tied into the security system? First time vette owner and appreciate any help.
Old Jan 2, 2009 | 04:13 PM
Oldguard 7's Avatar
Oldguard 7
No they are not tied to the security system. You can first try cleaning and lubricating the latch mechanisms and rods. You will have to remove the door latch to do this. There are posts in the archives with pictures on how to do this. Another option is to remove the door lock actuators and use your key to lock and unlock the doors and push/pull the door lock stem when inside the car. If you choose the latter, you will have non power locks of course. Welcome to the forum.
Old Jan 2, 2009 | 04:56 PM
a1sensei's Avatar
a1sensei
Mine never worked, the servos were bad. I took a long standard screwdriver and with the door panels off, popped the mechanism loose from the servo motor. No power, but they open much easier with the key!
God bless, Sensei
Old Jan 2, 2009 | 05:14 PM
Oldguard 7's Avatar
Oldguard 7
God bless, Sensei
Yup. I removed my actuators in my 79 in July 07.
Old Jan 2, 2009 | 05:20 PM
spedaleden's Avatar
spedaleden
R u getting power to the actuator?
Sometimes the switches need a new harness on te back. Check this also.
Old Jan 2, 2009 | 05:23 PM
78Vette-SA's Avatar
78Vette-SA
I had the same problem. Replaced the switch on the passenger side (which worked sporatically) and all is well.
Old Jan 3, 2009 | 06:11 AM
c3corvettes's Avatar
c3corvettes
Same problem here too. I replaced both electrical plugs. Both locks work as new.
Old Jan 3, 2009 | 10:14 AM
FB007's Avatar
FB007
What is an "automatic" door lock?
Old Jan 3, 2009 | 10:18 AM
SIXFOOTER's Avatar
SIXFOOTER
He means electrical
To 81 automatic door locks
