locktite or anitseize
Old Jan 3, 2009 | 08:43 PM
timd02's Avatar
timd02
Default locktite or anitseize
I am in the process of rebuilding the front suspension on my 75 coupe and wanted to know whether I should use locktite or antiseize on the suspension bolts. I read one thread where someone suggested using locktite on the bolts if using poly bushings but I am going with rubber. I don't want to worry about things coming loose down the road but also don't want any troubles when getting the front end aligned. Thanks for your help and insight.
v/r,
Tim
Old Jan 3, 2009 | 08:52 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
I use anti-seize on everything. Everything should have a lock washer or castle nut on it. Double nut anything you can. I have a bunch of anti-vibration washers also (double washers, serrated on each side)
Old Jan 3, 2009 | 09:28 PM
72LS1Vette's Avatar
72LS1Vette
I'd recommend loctite on the A-arm crossbar bolts. Those have been know to work themselves loose and fall out. I can't think of any other suspension bolts offhand that don't have either castle nuts/cotter pins or the special locking nuts (I forget the correct name).
Rick B.
Old Jan 3, 2009 | 09:36 PM
timd02's Avatar
timd02
Rick B.
Are you talking about the bolts that go through the bushings or the bolts that go through the frame?
Old Jan 4, 2009 | 12:09 AM
GDaina's Avatar
GDaina
Rick B.
I've never encountered that...and I've rebuilt countless front ends..torque me to spec and you're fine...
Old Jan 4, 2009 | 08:53 AM
SH-60B's Avatar
SH-60B
Definatly not the ones to the frame. The alignment shop needs to use those. I use antiseize on all of it.
Old Jan 4, 2009 | 10:34 AM
saudivette's Avatar
saudivette
When I stripped my front end, one A-arm cross shaft bolt was missing and 2 others were quite loose so I used "red" Loctite on them, torqued them to spec and then painted creep marks on the bolt head and A-arm. I torqued everything to spec though.
Old Jan 4, 2009 | 10:39 AM
jb78L-82's Avatar
jb78L-82
I agree. I have poly everywhere and just check every once in a while to make sure everything is tight. No issues!
To locktite or anitseize
