Another Trailing Arm dilema
Does this mean the bushings are shot??
I can get them out, but how difficult is it to repalce the bushings?
Any help or quidance would be greatly appreciated. I searched other threads, but not much is stated except it's a difficult task. Are there places that will remove and install new bushings for you? i live in the eastern shore Maryland area.
If you are doing all that work back there, why not replace the bushings. You can use poly on the trailing arms, they just slip in. Getting the old bushings out will be the hardest part. Rubber bushings must be compressed and the center sleeve flared. I've never done this part but I know that the guys who do it often have fabricated special tools for the job.
People debate on this forum from time to time about poly vs. rubber for the T/A bushings. If you want rubber, perhaps one of the vendors who does T/As will send you a set of bare arms, all painted and with bushings installed, in exchange for your cores and some $$.
My 2c
Cheers,
Chris
I personally prefer the rubber because they flex and do not ride as harsh as the poly. But it depends on what you want in ride and handling quality.
