AN Fitting question
Old Jan 8, 2009 | 08:58 PM
Iskenderian's Avatar
Iskenderian
Default AN Fitting question
Hello all,
I am nearly the end (knock on wallet) of my LT1 swap and am working on the Fuel lines. I want to do them in -6AN fittings. I figured out all the parts I need except the ones that will help me fit the braded steel lines with the stock steel lines that are stock on the car. (its 81 so it already has a return line) anyone have experience with AN fittings? I just did the tranny lines in braided steel and it came out great (pics as soon as I find my camera.
thanks
Bob
Old Jan 8, 2009 | 09:11 PM
Gordonm's Avatar
Gordonm
I am doing something similar to your setup. I am using the 3/8 fuel line as a return line for my setup. There are AN fitting that use a compression fitting on the steel line that go to an AN fitting. The 6 AN is an easy line to make up this way with a 3/8 line.
Old Jan 8, 2009 | 09:12 PM
speedreed8's Avatar
speedreed8
fittings like these, they are also available in black anodized. good luck
http://www.jegs.com/i/JEGS/555/100550/10002/-1
http://www.jegs.com/i/JEGS/555/100551/10002/-1
Old Jan 8, 2009 | 09:14 PM
Iskenderian
I saw those on summit, they always seem to refer to mating up with aluminum tubing. They work with steel too?
Bob
Old Jan 8, 2009 | 09:28 PM
speedreed8's Avatar
speedreed8
i dont know, the russell fittings say from a hard line to flex. hose.
http://www.jegs.com/p/Russell/747507/10002/-1
Old Jan 8, 2009 | 09:29 PM
Gordonm's Avatar
Gordonm
Some work with aluminum some work with steel. You just have to get the correct one. I went with Russell fittings but the others probably have the same type.
Gordonm's Avatar
Gordonm
Those are the ones I used.
To AN Fitting question
