Coil wire length
I'm fairly certain you're talking about the 7-9mm dia hi-tension "plug" wire from coil to center of MSD dist cap ... don't sweat 2-3 ft ... think of the race Fords with dist in front & coils on dash ... LONG run. Pretty dang unlikely you're running a resistance wire with a cd box as there's no 12vdc wire to either coil primary. Box supplies coil and box requires full 12vdc at all times.
a tip on wiring cd box-dist ... that pair of small primary wires that run from the cd box to the distributor ... at minimum, TWIST that pair about 1-2 twist per inch ... or shield them within a conductive jacket ... or both. Those are the trigger wires & twist/shield is how you help prevent interference from accidentally triggering a plug in the wrong phase.
I was running a Carne HI6 and a MSD magnetic dist. I did have those wires twisted and that setup ran flawless for many years. The rev limiter was set at 7000 rpm and I used it often.
Most all of it will be for sale once I get the FI up and running. Thanks for the info.
Okay so lets do the math so you can sleep tonight Gordon. With a 10,000 volt coil output and only 1 foot coil wire at 50ohms/ft then current is 10,000 divide by 50 = 200amps (instantanious) to the spark plug. Now with 3 feet of wire then 10,000 divide by (50 times 3) = 66.7 amps - a major change in spark energy.
And for a hi-energy ign at 50,000 volts: then 50,000/50 @ 1ft = 1000 amps and 50,000/(3'x50) = 333.3 amps.
But this is only chalk board talk as in reality the plug don't fire until enough electrons stack up at the gap - like a buildup before the dam breaks. I think this is why most ignitions rate thier outputs in joules of energy which is work done(at the spark gap).
Not to scare you here and so can sleep tonight just remember the spark has to continue to travel through the dizzy (jumping the rotor gap also) and down even more plug wire resistance to the spark plug. So if the coil wire is still shorter than the plug wire you haven't done anymore damage to the spark energy than the plug wire will do.
Good night,
cardo0
