HURST SHIFTER LINKAGE on 68 BB
Old Jan 17, 2009 | 08:38 AM
woodsdesign's Avatar
woodsdesign
Default HURST SHIFTER LINKAGE on 68 BB
Hi Guys,
I am re-assembling a 68 and need some help on the Hurst shifter linkage. Does anyone have a diagram of how the linkage goes from the shifter to the trans. The way I have it set up the reverse lever just barely touches the rod. I know that isn't tight. Any help would be appreciated.
Larry
Old Jan 17, 2009 | 11:54 AM
GDaina's Avatar
GDaina
linkeage is the same as the Muncie...you probably have to adjust the linkeage...put the tranny arms in neutral and then stick a drill bit, into the shifter, top of shifter frame to lock the arms, then adjust the linkeage...
Old Jan 17, 2009 | 06:55 PM
TimAT's Avatar
TimAT
I's also very easy to "flip" the shift arms on the trans. they still fit, but the rods won't quite reach. Something to check.
Old Jan 17, 2009 | 09:03 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old Jan 18, 2009 | 03:37 AM
roscobbc's Avatar
roscobbc
I initially did this too when installing
Old Jan 18, 2009 | 08:30 AM
woodsdesign
Paranoid, That is exactly what I needed. Thanks for the help. I flipped the rods.
Larry
To HURST SHIFTER LINKAGE on 68 BB
