[Cardinal Error!] Heater Core replacement
Old Jan 18, 2009 | 06:00 PM
BrentDev's Avatar
BrentDev
Default [Cardinal Error!] Heater Core replacement
made a cardinal error / sin....didnt check here first.
http://forums.corvetteforum.com/c3-t...er-core-2.html
Oh well -- got to practice pulling the dash again.
I had gotten it to the point to start tugging on the heater box, and I didnt like the way it felt, decided to come search here. Sure enough -- with a non-AC car, I ddnt even need to mess with the interior. Crap!
Anywho - motor cover came off simple to the engine bay. Two questions:
(1) how in the world to you remove the snap clip holding the core in?
(2) I didnt order the gasket between the two pipes (inlet / outlet) and there wasnt one before. Did anyone have luck getting those at local napa / autozone, or is that special order only?
So - lesson is -- always check here first for quick lessons before tackling jobs.
Old Jan 18, 2009 | 07:38 PM
Paul L's Avatar
Paul L
Needle-nose pliers. Yes, you will have to get that gasket from a Corvette supplier. But Goop will repair the old one very nicely.
Old Jan 18, 2009 | 07:49 PM
BrentDev's Avatar
BrentDev
thanks a ton Paul.....while I missed your thread too late, I didnt catch it TOO late.
Like I said, just have to put the dash back together.
Old Apr 27, 2009 | 08:15 PM
BrentDev's Avatar
BrentDev
Ok - back to work on the heater core.... I snapped one of those clips that hold the heater core in....
can you order those????
I can't find a part number in Corvette Central or Ecklers.
Thanks!
Old Apr 27, 2009 | 10:39 PM
MN-Brent's Avatar
MN-Brent
Try Doc Rebuild.
To [Cardinal Error!] Heater Core replacement
