Too much oil in engine....Any damage?
No one has synthesized petroleum.
Don't let anybody ever tell you, again that too much oil is ok, it'll just puke it out. No offense to anyone, I deal with 1500+HP engines, and that's not a good thing, PERIOD.
Then you are well aware that as soon as it starts, 1 qt stays in the upper part of the engine.
BBTank
If you're running a flat tappet cam, you should always break it in with a good high zinc dino oil to help the cam break in, then switch to synthetic after break-in period.
I agree with the others on the dino break-in oil. Also, don't flog that beast too hard when it's new! Even race engines get a break-in period on the dyno
Oh, the one that was real bad: Girl brings in her BRAND NEW Geo Metro and says it's making a wierd noise while driving and it has an oil leak. Seems her boyfreind offered to "show/help her" change the oil for the first time. He climbs under, drains the TRANSMISSION, adds 5 quarts of oil to the engine and sends her on her way. I had a heck of a time explaining to her father that the car had a ruined engine AND transmission and that it would not be covered by the dealer warranty. Thought he was gonna' kill me
Hans
1. Dino for break-in (until you achieve oil control/ seat the rings and the lifters mate), then go Mobil One.
2. It's not a good thing to use too much oil.
3. YOUR ENGINE IS FINE! Drain the oil, change the filter, put in 5 quarts of Rotella T and then DON"T WORRY ABOUT IT ANY MORE!
God bless, Sensei
Reality:
You can start using Mobil 1 in new vehicles at any time, even in brand new vehicles. In fact, Mobil 1 is original equipment (it is installed at the factory) in:
Acura RDX
Aston Martin
All Bentley Vehicles
All Cadillac Vehicles
Chevrolet Corvette C6 and Z06
Chevrolet TrailBlazer SS
Chrysler 300C SRT-8
Cobalt SS S/C Coupe
Dodge Caliber SRT-4, Charger SRT-8, and Magnum SRT-8
Jeep Cherokee SRT-8
Mercedes-Benz AMG Vehicles
Mercedes SLR
Mitsubishi Evolution
Pontiac Solstice GXP
All Porsche Vehicles
Saturn Ion Red Line and Saturn Sky Red Line
Viper SRT-10
One of the myths surrounding synthetic oils is that new engines require a break-in period with conventional oil. The fact is, current engine manufacturing technology does not require this break-in period. As indicated by the decisions of the engineers who design the high-performance cars listed above, Mobil 1 can be used starting the day you drive the car off the showroom floor. Watch our answer to this myth.
Wow, even Bently.
Years ago we used non detergent to breakin.
I guess things have progressed.
http://www.mobiloil.com/USA-English/...ics/Myths.aspx
Wow, even Bently.
God bless, Sensei
Or the proper suggested additive.
Such as
http://www.redlineoil.com/products_c...bCategoryID=35
Have done it both ways with no problems.
Well, synthetic oil is "dino" conventional oil, the only major difference is that the molecules in synthetic oil are uniform for better more even protection of metal parts. A synthetic oil is not some miracle magic lubricant, just an oil that allows wear to occur more slowly and evenly than a conventional oil. So much for those that think synthetics offer no benefit. I strongly suspect that those that have had problems using synthetics in recently built flat tappet engines or any newer engines were not due to the synthetic oil but either the engines were not built correctly or broken in incorrectly. IT'S NOT THE OIL!
Now for some personal experience:
1988 Mustang GT 5.0-Synthetic for 100,000 miles after 500 breakin with factory oil-Zero oil consumption.
Rebuilt 4 bolt Chevy 350 in 1986-Synthetic for 100,000 miles after 300 miles break in with Dino Oil-Zero oil consumption
All New Cars-Immediate switch to Synthetic when new-Most recent example 2001 Pontiac Grand Prix 3.1-Current mileage 95,000 miles- Zero oil consumption
1978 Corvette L-82 4 spd 3.70 gears-64,000 miles-Synthetic since 1985-Zero oil consumption-Roller rockers, new pushrods, valve stem seals in 1992-Immediate use of synthetic-Zero issues.
Every new piece of power equipment (lawn Tractor, snow blower, generator, etc)since 1994-synthetic from day one, no breakin with dino oil-zero engine issues, none replaced.
On a recently built engine, I would run dino (just to be safe) for 300-500 miles then change the filter and run synthetic based on the chemistry, industry experience and my own personal experience. On any new engine, be gentle for the first 1,000 miles. You will not be sorry.
Sensei, I'm truely amazed that you have those kinds of powers. Can you tell me why my rental car wouldn't go into overdrive on the freeway last night? Oh, I'm sorry, I forgot to give a little info. I'm staying in Medford OR, and I was driving back from Grant's Pass, OR. That should be enough info, huh??
I apologize for be such a smarta$$, but there is no way you can know for sure that no damage was done to that motor. I'm not there inspecting it, and I can't tell if it's damaged or not. You're probably right, but can't say for 100% sure.
BBTank
After 6000 miles i always change to Mobile 1.
When i buy a different car and i change the oil with the proper amount i drive it for a few miles and let it sit for an hour. I check the oil with the dip stick and if it doesn't match the line on the dip stick I use a small file and make my own mark.
Over 1/2 quart of oil like many have said is not good because it just froths up into tiny bubbles that will not pick up or lubricate properly.
I have had many cars since 1968 and everyone of them went over 150,000 miles and didn't smoke or use oil except my 82 Silverado that used 1 quart between changes but ran like new and never smoked. It puffed a tiny bit when started but thats it.
I had a re-curve job done on it and it still put out the original 190HP after the re-curve job at 170,000 miles.
Most of my engines have been the GM 6 cyl., 305 or the bullet proof 350.
I also have my trans. checked and oil changed once a year by the best trans. guy I've ever had, Leons transmission in Garden Grove California.
Never ever had one go bad after they do their magic and i pulled a huge 5th wheel for years with that 2 bolt main 350 in the Silverado with a 4 core radiator.
This was a little long but for those that don't know this info it will save ya a ton of bucks as it has for my kids.
Wrong, Redline, Amsoil and I believe Royal purple are truly synthetic. They are not made from a mineral base. I think most of the others synthetics are mineral base but have been processed so much that they now can be called synthetic.
SYNTHETIC LUBRICANTS
Synthetic lubricants are chemically engineered from pure chemicals rather than refined from crude oil. That gives them significant advantages over refined oils.
Pure - The feedstocks from which synthetic lubricants are made do not contain sulfur, nitrogen or other elements that invite the formation of sludge and other products of lubricant breakdown. Synthetic lubricants can be used in higher temperatures than refined lubricants without breaking down. Their resistance to breakdown also allows them to be used longer than refined lubricants can be used. Lubricated systems stay cleaner and last longer with synthetic lubricants.
Synthetic lubricants differ from refined oil in three key ways: synthetics are pure, their molecular structure is uniform, and they may be designed to work in applications in which refined oils cannot.
Uniform - The feedstocks from which synthetic lubricants are made feature uniform and smooth molecular structures, which ensures low friction as lubricant layers slide across one another. Reduced friction increases energy through-put for greater fuel efficiency and power and reduces heat and wear for longer equipment life.
Molecular uniformity also helps synthetics resist thinning in heat and thickening in cold, which helps them protect better than refined oils over a system's operating temperature range and helps ensure secure sealing.
"Field experience has shown that synthetics can give economic benefits when used in place of mineral oils which were working satisfactorily. The benefits fall in five general areas:
* Improved energy efficiency
* Wider operating temperature range
* Increased design ratings
* Reduced maintenance
* Better reliability and safer operation"
- A. Jackson, Mechanical Engineering Transactions
If it runs fine, what do you suggest? Rebuilding because a spec is off? What's the point?
