Please help me wire my computer HEI to ECU
Bee Jay
Bee Jay
I actually took a picture of my plug but the wire colors are all hard to make out and you can't read the letters.
However, if you're looking at the plug so you can read the letters, they go from left to right like this. D, C, B, A.
Here's a pic, with color coding that corresponds to your new plug.
so that leaves just 3 wires.....now on the chip itself they are stamped B R E from outer edge toward the middle.....
B is your interrupt wire, the Tan Black that you pull to set base timing.....8*
E is the wire for EST, a signal wire to the computer, typically white.....
R is the Reference wire, and is typically purple with a white stripe for my stuff.....
the base timing ref, nothing but a 0-5 pulse after modifying the signal from the magnetic coil on bottom, is what the car will run with, it will act the same as a normal HEI with vacuum advance when the feedback wire is pulled to set timing, ie...NO advance, as it it not told to advance a damn thing by the computer,.....so the dawg just set there....
when you reconnect the tan/blk or Bypass wire, you get a signal from the computer telling the dizzy to advance and by how much.....when you restart the car, it will not do that untill you kill and restart the engine....
hope this helps.....I dunno whay/why DB's pix there is different than mine....
aftermarket wiring??? dunno...
but go by the markings on the large black chip on the dizzy base with heatsink compound....
My distributor has the same colored wires, but his after market one has odd colors so I just matched them to their corresponding color on his distributor for him.
Bee Jay
Bee Jay
You can see the letters on the weatherpack connector. DB says that abcd should hook up to dabc. I think I have it right. Check it out and comment please.
Bee Jay
Bee Jay
OK, the dizzy is in and the car finally started. With no vacuum advance nipple to point at the valve cover bolt, my usual starting point, it took a while to find a good clocking to get the car started. Once running, I set the initial advance at 10 degrees idling at 900 rpm. But when I rohooked the red ECU advance wire, the car started running really bad. The fuel injection graph is set at 8 degrees at 700 rpm, so I assumed that it would be 8 degrees plus the 10 I set initial, or 18 degrees at idle. Just where the car always loved to run. I put the timing light on it and it read 8 degrees. The computer took 2 degrees out to get it to the 8 degrees in the table/graph. So now I have to build an advance table. With my weights and vacuum, I always set it for 38 degrees centrifugal, all in by 2500 rpm. Plus 10 degrees vacuum thrown in at low load, high vacuum situations. So, I'm guessing I build the table with 38 degrees total advance at high throttle openings above 2500 degrees, 48 degrees total advance above 2500 degrees at low throttle openings. I'll go look at Lars papers again, but am I on the right path? Help!!!
Bee Jay
