I recently picked up a 70 LS5 4 speed. the motor is fresh, has headman headers, holley 750, transistor ignition. It was real slow when I got it, found it had a broken plug. I set the timing at six degrees, disconnected the TCS, it has no smog pump. The car will burn rubber like no tommorrow, however it does not seem to have the power it should on top, in fact it does not seem to want to rev past 4000 rpm, not that it cuts out or anything, just seems flat. I tried differnt secondary springs in the carb, but did not help much.
springs to tight? to loose? no good? I almost thought maybe the cam is flat since the motor is new and who knows how they broke in the cam. But it screams when burning out?
You might just have a truck cam and an intake that's targeted at the lower RPM band. Maybe it was built for torque and not for winding up.
The fact that it has great torque and runs out of steam leads me to finger the cam and/or lower than stock compression.
Since it doesn't miss or hesitate when it stops pulling, check the total advance and see what your getting around 3500 rpm. If it is the cam or compression, you should be able to run quite a bit of timing and still not experience any detonation. Yuo have plenty of carb and exhaust on paper, and without knowing exactly which heads and pistons you have that my best guess for now. If you have access to a boroscope, you can verify the pistons, and the head numbers should fill in the picture a bit as well.
Put a high quality fuel pressure guage on it where it can be read when the motor starts to "fall on it's face"......, in other words, on the outside of the windshield in front of your face so you can read it when you're a WOT in high gear (not under the hood). Big blocks need alot of fuel. I have a mid 10 second '67 Nova I drag race that had a similar problem until I put a second Holley "blue" elec. pump on it. One pump just wasn't getting the job done.
Also, make sure your dwell is set correctly (can cause symptoms you describe). 6 degrees timing is low - I agree with Wrencher - adjust TOTAL timing (in by around 2-2.5K).
Read Lars or Barry's papers for more specifics on timing.
Hans
I did check the casting numbers on the block and heads and they are correct for the 70 LS5. The previous owner gave me the number to the shop who redid the motor, and when I called them they told me they did an exchange motor. This puzzled me even more since it has the correct casting numbers. I did check the compression and it pumped out 180 pounds cold.
I thought of this also, it has the correct intake but I don't know about the cam, as I said in another reply the shop that did the motor for the previous owner said they did an exchange, so I thought maybe they put a truck motor in it, however the casting numbers are correct for the 70 LS5.
Put a high quality fuel pressure guage on it where it can be read when the motor starts to "fall on it's face"......, I have a mid 10 second '67 Nova I drag race that had a similar problem until I put a second Holley "blue" elec. pump on it. One pump just wasn't getting the job done.
I'd be suspicious, among other things, of a lack of fuel pressure also. I've had a 69 and 70 BB. I've always been suspicious that the factory designed the cars to run out of fuel pressure at high loads/high rpms. A motive would be liability problems of the 1970's. No real substantive reason for this reason other than the engine dying off in power was consistent with a lack of fuel.
No dwell, the distributor looks like it has the electronic conversion kit I see in mid americas catalog.
I have the adjustable timing light, what should the timing be set at 3000 RPM?
Sasha, I have a different though for you to check out. If you have brutal low end torque and it runs strong when cold but it just hits a wall at @ 4000rpm. Your timing chain is off by 1 tooth. I had a worn timing chain jump and that sucker ran like a duramax on steriods up to 3000rpm than nothing. Good Luck PS if it was a fuel pressure issue it would surge. IMHO
Reason: miss spelling
