big block won't rev
Old Jan 20, 2009 | 11:38 PM
BigBlockTank's Avatar
BigBlockTank
Originally Posted by hugie82
Sasha, I have a different though for you to check out. If you have brutal low end torque and it runs strong when cold but it just hits a wall at @ 4000rpm. Your timing chain is off by 1 tooth. I had a worn timing chain jump and that sucker ran like a duramax on steriods up to 3000rpm than nothing. Good Luck PS if it was a fuel pressure issue it would surge. IMHO
BINGO, I was looking for this to see if anyone posted this suggestion.
Folks, I think we have a winner right here.
If valves were to tight you'd get a reaction from the carb. If they were too loose, you'd hear them.
Let us know what you find????
Tank
Old Jan 21, 2009 | 12:27 AM
69elky's Avatar
69elky
Default Rev limited
Just a question,just a thought,this car does not have a rev limiter intalled such as a MSD 6 AL box has were you can change your rev limiting by plugging in different chips of different values.Again just a thought.
Old Jan 21, 2009 | 10:15 AM
hugie82's Avatar
hugie82
The engine would bounce off the rev limiter. Like a miss fire
Old Jan 21, 2009 | 10:20 AM
hugie82's Avatar
hugie82
Tank
You know it Tank! Over the years we all have been their scratching are heads saying "Man its won't rev but it sure has some torque or Man it rune like a raped aped after 4000 RPMs"
Old Jan 21, 2009 | 12:54 PM
GDaina's Avatar
GDaina
as someone else mentioned above...tight valve lash will prevent higher revs....
Old Jan 21, 2009 | 11:09 PM
BigBlockTank
As someone else above mentioned (BBTank) if the valves are too tight, won't it be talking to ya thru the carb/exhaust? Damn sure does every time I get mine too tight. just a thought.
Old Jan 22, 2009 | 11:05 AM
GDaina's Avatar
GDaina
I never had that problem...but when I lashed my valves tight, it took forever to rev to 6K and strained to rev to 6.5K...when I loosened the lash by .002, all was well...
Old Jan 24, 2009 | 01:47 PM
sashabigdeal's Avatar
sashabigdeal
Originally Posted by howarsc
Try 30-35* at 3000rpm with vac adv unplugged. This may do it.
LOOKS LIKE IT MAY HAVE BEEN THE TIMING!
I want to thank everyone for there advice. Had my neighbor come over and I set the total advance to 35 @ 3000 RPM. i then checked it with the vacuum pluged in and it goes up to maybe 44. We took it for a ride and it definatly revs better, i got it to 4500. I also notiiced a slight miss now and found my number one plugwire melted on the headers and arcing. bought new wires and the miss is gone, sounds good, but it has been raining here and I can't go do a speed run.
I will update everyone when I get a chance to run it.
Old Jan 24, 2009 | 03:03 PM
WESCH's Avatar
WESCH
Hi
All concentrating on timing, weather it is just not advanced enough or even one tooth off on the timing chain, but are you sure that the secondaries on your carb are working ?
4000 RPM under load is about when they should add their fuel.
Could be no fuel at all or even simply not opening up .
Just an idea .
Good luck. Gunther
Old Jan 24, 2009 | 03:58 PM
sub006's Avatar
sub006
"They all do that"
-Small-block lover
LOL!
Old Jan 24, 2009 | 04:39 PM
howarsc's Avatar
howarsc
Originally Posted by WESCH
Hi
Just an idea .
Good luck. Gunther
A small leak in the seconday diaphram can be part of it as well. Ensure the secondary linkage opens smoothly all the way with it NOT running and then check the diaphragm if you still don't have a strong 5000+ rpm.
Good luck,
Scott
Old Jan 24, 2009 | 05:31 PM
roscobbc's Avatar
roscobbc
Originally Posted by sly vette
Not enough advance, IMO!
My L36 ran up to 4500 and that was it. Added headers, low restriction mufflers, Torker 2, Holley 750 DP, MSD, timing 36 degree total all-in at 2200 rpm - it was now really sharp and would rev up to 4500 rpm
OK so it would build-up under protest to 5100 rpm - but it just ran harsh. Came to the conclusion it was well past its sell by date and that the cam was a bit 'soft'.
What a difference with my new 489 the extra 1500 rpm makes
Old Feb 5, 2009 | 10:41 AM
  #33
sashabigdeal
is the 489 the cam you put in it?
