brake fuild
Old Jan 22, 2009 | 06:41 PM
69small block's Avatar
69small block
Default brake fuild
I was at the local advanced auto today and wanted some brake fluid everything in the store said synthetic so I asked they said its the same as before that they just now did the label change that its always been synthetic its that so I am confused about this antone out there clear this up as I need to put brakes system back together
Old Jan 22, 2009 | 06:50 PM
Bowerss2's Avatar
Bowerss2
dont worry about synthetic, any dot3 is fine, its a buzz word, just avoid "silicone" fluid and you will be fine, cheers
Old Jan 22, 2009 | 07:22 PM
dariopop's Avatar
dariopop
That confused me at 1st also.
Old Jan 22, 2009 | 07:50 PM
Mad Vette's Avatar
Mad Vette
Why avoid silicone fluid?
Old Jan 22, 2009 | 08:17 PM
LB66383's Avatar
LB66383
Silicone (DOT 5) fluid doesn't play well with the DOT 3 and DOT 4 fluids. If you're going to switch to silicone fluid, it is strongly recommended that you rebuild the calipers and master cylinder to remove all traces of the old fluid, and flush out the system for the same reason. Otherwise, you'll likely end up with leaks and system failure in the near future.
Old Jan 22, 2009 | 08:20 PM
Bowerss2's Avatar
Bowerss2
Silicone fluid is functionally incompatible with systems that have held glycol-based fluids for any length of time, requiring flushing and seal replacement (there are counter opinions on this, which state that the modern silicone formulations are in fact compatible with only a flushing, rather than a complete reseal). The actual DOT specification requires chemical compatibility, so as far as that goes, the two fluids won't cause reactions if used in the same system, but they certainly won't mix, either.
i have seen some reactions mixing dot 3 standard with dot 5 silicone, it turns into jelly, and creates headaches upon headaches.
Old Jan 22, 2009 | 08:49 PM
69small block
Default brake fluid
thnaks for the info guys I am just in the last stagesa of an rebuild of the rear suspension of my 69 vert redid the t/a new rear spring u joints did all the works myself including the bearing suports its was a great project to do gary and mike were a great hlep too lots good andice but all is ready to go back in now noting fancy on the paint od the parts just a black satin I drive the cart as much as possible that what vettes are for right
Old Jan 23, 2009 | 08:59 PM
Mad Vette's Avatar
Mad Vette
I did not know that I thought that maybe there was problem with silicone. I have had silicone in my car for 5 years but my whole system was new when it was installed and I have not had any problems. But I will make sure that that I dot mix in dot 3 or 4 in.
Old Jan 23, 2009 | 09:09 PM
L79racer's Avatar
L79racer
My family has used silicone in our vettes for over 20 years. We just drain the old fluid and flush or bleed with the silcone fluid until its all cleaned out. We have never experience a problem from it. The vettes are 63 convert. 63 coupe, 66 coupe, 67 convert, 69 coupe. We will add a 75 and 80 to the list after we redo the brakes.
Dont forget silicone wont eat the paint off your car like other brake fluids.
Old Jan 24, 2009 | 09:36 AM
99 Black Bird TA's Avatar
99 Black Bird TA
Also DOT 3 & 4 will absorb water while DOT 5 won't absorb water. However, water still works it's way into the braking system.
I've been told, a DOT 5 system that's never flushed to get the accumilated water out of it etc and replace with fresh DOT 5 will accumilate water in time that will effect performance. In hard braking conditions the little water pockets can boil etc and cause erratic brake performance similar to air the brake lines.
Old Jan 24, 2009 | 12:21 PM
SoCalErv's Avatar
SoCalErv
Army
If you are restoring the brake system switching to silicone is the right choice. It can be a bear to bleed the first time around but it is worth the effort.
It is similar to a LNG engine, it will work forever and when you pull it apart it is clean.
Old Jan 24, 2009 | 04:59 PM
thegazman's Avatar
thegazman
Old Jan 25, 2009 | 11:57 AM
captl27's Avatar
captl27
So you say if all my lines are new and all my calipers are new and my master cylinder is new I should go silicon no questions asked?
Old Jan 25, 2009 | 12:50 PM
MN-Brent's Avatar
MN-Brent
Go to Autozone and buy the Valvoline "synthetic" DOT3 DOT4 brake fluid (bottle is labelled as both!!) or the Castrol GT LMA DOT4 fluid and sleep well at night knowing your braking system is just fine.
I have read about DOT5 not having the same compression characteristics, which could give you a funky pedal feel, and can be a problem unless you have a 100% clean new brake system.
If you go through the trouble of that and find its not your cup-o-tea, you now have a system that needs to be thouroughly cleaned of it.
My .02
Old Jan 25, 2009 | 05:07 PM
thegazman's Avatar
thegazman
Default thegazman
Look up silicone brake fluid on the internet. I read one article that said if your master cylinder leaked silicone fluid into your brake booster it would be sucked into the engine. It turns into sand when burned. Regular brake fluid will burn with your gasoline.
Old Jan 25, 2009 | 10:55 PM
captl27's Avatar
captl27
Thanks both of you for the heads up. I have heard to much bad stuff about silicone I will be going with dot 4
Old Jan 26, 2009 | 12:56 AM
Z-man's Avatar
Z-man
What??? That's silicon...not silicone. They are as different as "Silicon Valley (San Jose)" and "Silicone Valley (Hollywood)".
Too many words that start with an "S" are being discussed in one thread...
To brake fuild
Old Jan 27, 2009 | 06:01 PM
thegazman's Avatar
thegazman
Default thegazman
Actually we were talking brake fluid. Not sure what you're talking about.
Old Jan 27, 2009 | 06:27 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default Dot5
I have had DOT 5 silicone fluid in my 68 and 70 for over 20 years, for sure have no intentions going back to DOT 3 or DOT 4.
My 70 has power brakes and I am still amazed at the braking potential it has with silicone and power brakes.
With the Vette Brakes suspension front and read, it just stops so quick and straight, just hunkers down.
Old Jan 27, 2009 | 07:12 PM
SuprJames's Avatar
SuprJames
Rumors and myth. I have two Vettes with silicone brake fluid and they both brake just fine and one has done so for more then 6 years.
I would not go with DOT 5 unless you're replacing everything though.
