Engine heat inside the vehicle
Old Jan 24, 2009 | 03:05 PM
Yohon75's Avatar
Yohon75
Default Engine heat inside the vehicle
I recently had a 383 installed in my 77. As you all know, this engine gets warm pretty fast. On a nice cool day, it is very comfortable to drive in but on hot summer days, especially here in Texas, it actually can be quite miserable. Does anyone have any ideas or suggesstions on a way or ways to help reduce the engine heat from seeping inside the vehicle? Thanks for your time.
Old Jan 24, 2009 | 03:15 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Sorry, the 383 doesn't get hotter than the 350, it's just that C3s had really poor heat insulation. Best thing is pull the carpet & fully insulate the cabin with Cool-it, Reflectix, DynoMat, or something similar. Thermo-Tec makes a sleeve that fits over your exhaust pipes (not wrap) to help control the heat. Also look for any holes in the firewall that are not plugged. Grommets may have gone bad, you can leak a lot of heat there. Header coatings help lower the underhood temps too.
Old Jan 24, 2009 | 03:56 PM
tak82's Avatar
tak82
I used the foiled bubble rap you get a LOWES, it's works real nice even on a ot day. It'll take some contact cement or good spray adhesive to hold it down.
Old Jan 24, 2009 | 05:00 PM
7T1vette's Avatar
7T1vette
Yohon 75:
There are about a dozen common problems that can cause unwanted heat to get into the interior of a C3. They are in various 'categories'... 1) engine/exhaust running hotter than it should; 2) engine heat leaking into the interior (via faulty ducting/seals/etc. or unsealed passages into the interior; 3) inadequate insulation under the carpeting [this is a given, you must correct this one to even have a chance at solving your heat problem]; heat/vent/A/C system allowing heater core to vent heat into cabin when it shouldn't.
And there are several sub-causes that can fit into each of the above 'categories'. There are some good manuals that detail all of the possible issues and solutions for each. You really need to do a good assessment to find out which ones are affecting your car. I can guarantee you that there will be more than one cause...probably 5 or 6 items you need to resolve to get the heat down. I would tell you the title and author of the manual I used to fix mine...but I can't find it, sorry.
P.S. DynaMat is a sound insulator, not a heat insulator. It will take the cabin longer to reach a stabilized heat level using DynaMat; but it will (eventually) get just as hot with it as without it. I used Reflectix and it works well; it is also the least expensive of that type of fix.
Old Jan 24, 2009 | 05:35 PM
SIXFOOTER's Avatar
SIXFOOTER
With all the above. One of the keys is to stop the heat from getting to the floor. There is a product out there called Lizard skin, it is a thick paint that you would paint on both sides of the floor pans and up onto the firewall. It cost about $175 for 2 gallons last time I looked. Fortunately you can make the stuff with Home Depot Oops paint and some stuff called "Micro Spheres" availabe at Aircraft restoration suppliers (Moodys?) can't remember the name of the place right off hand. It cost about $10/gal and you only need 1.
Like 7T1 says the heat comes from several places, you have to fix them all.
Old Jan 25, 2009 | 09:01 AM
dmaaero's Avatar
dmaaero
Here"s a good example of what 7t1vette is talking about (various locations). At a stop light my fresh air vents would fill with engine comparment heat, thru the wiper tray. When you took off the cabin would go to 130 degrees!!!!!!!!! I now allways close the vents when i stop, wait till fresh air starts coming in thru the hood cowel before i re-open the vents. Makes quiet a differance an it"s free.
Old Jan 25, 2009 | 09:09 AM
wfo76's Avatar
wfo76
One way to find holes and faulty grommets and seals is to get one of those utility lights (light bulb with a hood) and put it on the floorboards of your car pointing forward. Go in your dark garage and open the hood and any holes or leaks will be easy to spot with the light shining through.
Old Jan 25, 2009 | 03:02 PM
ROBRICCI's Avatar
ROBRICCI
Default this is what i did - knowing my 454 would get HOT
Old Jan 25, 2009 | 08:05 PM
OzzyTom's Avatar
OzzyTom
I too had issues with extraordinary heat buildup in cabin.
Like Texas, here in Adelaide, South Australia we also have extremely hot summers... it'll be over 105* this week
A combination of fitting reflective aluminium fibreglass matting on the underside of my firewall and floor pan including trans tunnel, ceramic coating of headers (note custom headers to route the pipes along tunnel, rather than under floor pan) and under carpet insulation inside the cabin have improved the situation immensely.
Airconditioning now actually has a chance to work effectively
Old Jan 25, 2009 | 08:21 PM
spedaleden's Avatar
spedaleden
I had the same problem and I used Dynamat on the interior but my biggest problem was the air coming in through the vents. That temp was always 100 degrees once the engine warmed up. I placed a thermometer in the vent to check temp. What I found was engine compartment air seeping into the air ducts. I went and resealed everything and now the temp from the air cond vents is the same as the outside air when set on vent. The air conditioning in the car gets down to 30 degrees and the car stays cold with glass tops.
The body does let heat in, but I think most time there's more heat coming in through the air conditioning housing or firewall leaks.
I agrree with the above also
Old Jan 25, 2009 | 08:29 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You guys have to remember too! Some cars did not have the hot water shut off valve and with a blower motor that always runs this is bad! You will always be circulating hot water over the heater core and this will hinder the output of your AC system as well.
While the factory never used any of the heat barriers like you guys have installed, they are highly recommended on any C3 car. (Robricci and Ozytom both have done real nice jobs intalling theirs).
You may also want to take a look at this page if you have heat coming in from around your console area. http://willcoxcorvette.com/repairand...lp.php?hID=163
Ozzytom, I'd take 1/2 of your temp today, were around 12 degrees right now and boy it's cold outside.
Willcox Inc.
Old Jan 26, 2009 | 01:08 PM
Vette80regon's Avatar
Vette80regon
I love the heat!!! I removed all heat/duct/heater core etc for track days, weight savings, ease & simplicity. It's all fine & dandy until days like today when it's not rainy & I decide to drive the Vette to work... (it's sunny, but 29 degree's!!!!)
wishin' I had some more cabin warmth.
btw... Your ride is coming together nicely
Old Jan 26, 2009 | 02:26 PM
stingraynick75's Avatar
stingraynick75
Originally Posted by Vette80regon
I love the heat!!! I removed all heat/duct/heater core etc for track days, weight savings, ease & simplicity. o It's all fine & dandy until days like today when it's not rainy & I decide t drive the Vette to work... (it's sunny, but 29 degree's!!!!)
Great idea, I will uncover mine and blow out the cob webs
Old Jan 26, 2009 | 02:29 PM
aaroncorvette's Avatar
aaroncorvette
No probs here either, my foot feels like its going to melt after about 50 miles but i'm grateful as its usually so cold outside!
Old Jan 26, 2009 | 03:11 PM
fe1ixdakatt's Avatar
fe1ixdakatt
Willcox Inc.
The manual shut-off valve is my next project. I just went searching for parts this weekend.
While I'm on the subject, quick question..... if my heater hose is 3/4", is the hose going to fit over a 3/4" Ball Valve with solder ends or do I need to buy something slightly smaller to get the end of the hose over the edge of the valve? I purchased a 3/4" ball valve and the width of the openings looks really close to that of the hose. I'd hate to hack the hose or go through the trouble of draining and disconnecting if it's not going to fit over that valve. Also, any way to verify which one is the output hose and which is the return? One is 3/4" and the other appears 1/2"... just want to be sure I install it on the right one.
Old Jan 26, 2009 | 05:21 PM
Dantana's Avatar
Dantana
There's a lot of data on this topic on the Forum. Try doing a search and see what pops up - my guess is you will get a small novel worth of reading material. Good luck.
Old Jan 26, 2009 | 05:24 PM
heavy_d's Avatar
heavy_d
Have you checked the hood weather seal? A bad seal will allow heat into the cabin also.
To Engine heat inside the vehicle
