wiring guru's help please
Old Jan 24, 2009 | 09:21 PM
jagan's Avatar
jagan
Default wiring guru's help please
The front marker and turn lights come on when I step on the brakes. The dash turn indicators stay lit when the ignition key is on. Any ideas?
Old Jan 24, 2009 | 09:56 PM
wombvette's Avatar
wombvette
Originally Posted by jagan
The front maker and turn lights come on when I step on the brakes. The dash turn indicators stay lit when the ignition key is on. Any ideas?
Have you just installed a wiring harness or turn signal switch? Sounds like the wires are switched at the connection.
Old Jan 24, 2009 | 10:53 PM
klb6469's Avatar
klb6469
Sounds like the emergence flasher switch is pushed in and the flasher unit is bad.
Old Jan 25, 2009 | 01:58 AM
wombvette's Avatar
wombvette
Yep, That would do it.
Old Jan 25, 2009 | 11:32 AM
7T1vette's Avatar
7T1vette
Flasher unit must have failed in the "ON" state. Good call!
Old Jan 25, 2009 | 06:29 PM
KevinZ's Avatar
KevinZ
Did you find your trouble????
If not:
Check for a bad ground for the brake and signal lights.
Turn signals share the wiring front and rear but brake lights are separate while using the same filament in the rear lamp. Bad rear ground can use best path which makes other lights to come on to complete circuit. This would also account for the dash lights to come on. Also check turn signals with the parking lights on to make sure all are working properly.
Old Jan 25, 2009 | 07:13 PM
jagan's Avatar
jagan
It was the headlight switch. What a pain in the ___!
To wiring guru's help please
