Are Half Shafts Balanced
Old Jan 25, 2009 | 12:30 PM
RippoDippo's Avatar
RippoDippo
Default Are Half Shafts Balanced
Looking at a new set just got from Van Steel and was wondering if these get balanced?
Don't see any centres point thats been dimpled.
If so how they held in a blancer to be done? or not needed.
Thanks!
Old Jan 25, 2009 | 01:54 PM
A88FXRS's Avatar
A88FXRS
i don't believe halfshafts for street use are balanced. maybe for high speed racing application. driveshaft is balanced from factory.
Old Jan 25, 2009 | 02:00 PM
Steve COSD's Avatar
Steve COSD
Thanks!
I would call Van Steel. Any rotating mass should be balanced. If it's not it will destroy itself and probably other things.
Old Jan 25, 2009 | 03:48 PM
willem wallace's Avatar
willem wallace
Default Half Shaft Balancing
I think one of the best vendor deals I have received to this point on my 1971 basket case restoration were the half shafts I purchased from Fort Wayne Clutch. I received a set of brand new half shafts, constructed of thicker and larger than OEM tube stock, brand new Spicer fittingless u-joints, and brand new(not reconditioned) mounting flanges. $166.00 to my doorstep (2006). Build quality was excellent, and shafts had both been balanced, via small pieces welded to shaft ends.
Old Jan 25, 2009 | 04:41 PM
terry82's Avatar
terry82
have bought a lot of parts from them .u-joints and strap kit for my half shafts last summer .the guy knew the part numbers in his head .
Old Jan 25, 2009 | 05:06 PM
Kellys~hotrods's Avatar
Kellys~hotrods
I would think that they need to ba in ballance. If not, you may experience vibrations coming from the rear end, and premature U-joint wear/ failure. I would imagine out of ballance conditions would not be very kind to the center section or trailing arm assemblies either.
Kelly
Old Jan 25, 2009 | 06:33 PM
7T1vette's Avatar
7T1vette
If there is any balancing done on half-shafts (by their manufacturer), it would be on the end yokes. There is no need to balance the tubing; and the welding is done with robotics, so it is uniform. The radius of the tube is 3" (max), and at the rotation speed at top vehicle speed {roughly 1000 rpm} wouldn't produce a significant vibration.
Old Jan 25, 2009 | 06:37 PM
Kellys~hotrods
Good to know, I thought vibration magnitude would be affected by the ammount of mass that is off center (how far out of ballance the part is) instead of rotational velocity (i figured would affect the frequency of vibration).
Kelly
Old Jan 25, 2009 | 06:44 PM
wombvette's Avatar
wombvette
Agree: The radius being very small and the low speed will not produce much if any vibration.
Old Jan 26, 2009 | 12:33 AM
Droptop-Rob's Avatar
Droptop-Rob
The half shafts where not balanced from the factory. I seen this topic brought up on the NCRS board years ago, and that was the consensus.
Old Jan 26, 2009 | 10:05 AM
jazz81's Avatar
jazz81
with 71 vette. My older vette had small dents in one of the half shafts which caused no vibration or premature failure to universals
Mark
Old Jan 26, 2009 | 10:14 PM
Mike Ward's Avatar
Mike Ward
They don't turn fast enough, have a big enough diameter or carry enough mass to make any difference.
Old Jan 27, 2009 | 09:45 AM
TopGunn's Avatar
TopGunn
Was that for 2 or 1? That seems like an incredible price for 2, Van Steel gets $150 for 1. Just the flange is $45 from him. I can't see how he's that far off base if the Ft Wayne price is for 2. ???
Bill
Old Jan 27, 2009 | 10:33 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Bill
Ft wayne recently raised their price. Until a couple years ago they were $150 for 2 with spicer u-joints, new flanges, balanced and assembled
Old Jan 27, 2009 | 11:26 AM
tshort's Avatar
tshort
CI 7-8 Veteran
I just got some 3" .134" wall with solid spicer's and flanges from Fort Wayne together for $270 to my door. Their prices have gone up but still a darn good deal. And yes, they're balanced.
Old Jan 27, 2009 | 11:35 AM
TopGunn's Avatar
TopGunn
OK..... thank you. Inflation takes it's toll pretty fast these days I guess. Still sounds like a good price.
To Are Half Shafts Balanced
