Trailing arm replace...new or rebuilt
Old Jan 25, 2009 | 03:19 PM
ctrain22's Avatar
ctrain22
Default Trailing arm replace...new or rebuilt
My trailing arms and bearings are original. I don't have any problems with them at this time, but in the future, I know they should be replaced. Has anyone installed the rebuilt arms from CC or Zip? How do they compare to new in quality? They are more than half the price of new. Any suggestions??
Old Jan 25, 2009 | 03:26 PM
Grumpy 427's Avatar
Grumpy 427
I sent mine of to Bairs for rebuilding, they came back in better than new condition.
Old Jan 25, 2009 | 05:01 PM
GTR1999's Avatar
GTR1999
If yours are not rotted out or bent then rebuild those. A CA car,those arms are probably in better shape then any exchange arm. You can rebuild yours and know what you have.
Look up my threads on the job, maybe you can tackle it yourself.
Good luck
Old Jan 26, 2009 | 05:12 PM
Hard Core Vette's Avatar
Hard Core Vette
Navigator
If the outside of the arms are badly rusted then the inside is worse. If the outside can be cleaned up without pitting then just do the best you can sandblasting the insides and rebuild them. We have a TA rebuild kit, tools and instructions on our website including Timken bearings and new SS parking brake parts. Here is a link to the page.
http://www.duntovmotors.com/SpindlesParkingBrakes.htm
Old Jan 27, 2009 | 02:34 PM
Rally68's Avatar
Rally68
If the arms themselves are in good shape and you have the money, send them out. There are several good rebuilders, if you search the forum you will learn everything you ever wanted to know.
I am halfway through rebuilding mine, doing all the work myself. It is a big job. GTR1999's threads have been invaluable. Got most of the parts (bearings, seals, E-brake kit) from Duntov. They also sell the spindle knocker and "rent" the spindle tools, which you must have.
I really enjoy the time I spend working in the car, and also learning about how it all goes together. That said, if I had it to do over, I would send them out. I will save money in the end, even after having bought a (used) press, micrometer, dial guage stand, bearing splitter, spindle knocker, etc. The problem is, with the time I've spent, the money I saved works out to about $3 an hour
Old Jan 27, 2009 | 04:38 PM
Smooth72's Avatar
Smooth72
If you want to put wider tires on it you can get offset trailing arms. I got mine from VBP.
To Trailing arm replace...new or rebuilt
