Aluminium prop, any good?
Old Jan 26, 2009 | 04:52 AM
aaroncorvette's Avatar
aaroncorvette
Default Aluminium prop, any good?
I've just purchased a tremec 600 from Keisler and while i was there i upgraded to the aluminium prop, does anyone know the weight difference from the stock prop? thanks. Aaron
Old Jan 26, 2009 | 02:22 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I don't know directly but typically aluminum components are 2/3's to half the weight of an equivalent steel part.
Old Jan 26, 2009 | 05:04 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Don't know what your driveshaft weighs, but my stock shaft on my '69 weighs 9 1/2 pounds with both u-joints installed (subject to scale accuracy).
Old Jan 27, 2009 | 04:52 PM
aaroncorvette
Thanks, i'll weigh my ali prop when i get it and post results
Old Jan 28, 2009 | 08:35 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
What diameter did you get? If you upgraded to a 3" diameter shaft, make sure you have plenty of room between it and the body.
I had one in my car for several years and everything was good. However, when I switched from poly body mounts back to factory rubber mounts to reduce squeeks and rattles the body would shift over enough under hard cornering on road courses to hit the shaft. It ended up with 3 really nice rings machined into the shaft. I'm back to using a steel 2.5" drive shaft now ... that was a bummer.
So just a word of caution, check clearances and make sure there is at least 1/4" all the way around ... and maybe consider poly body mounts too if you drive your car hard. I think I only had 1/8" clearance at the problem locations.
Old Jan 29, 2009 | 07:44 AM
aaroncorvette
great info, i'll ring keisler and ask them the diameter
Old Feb 10, 2009 | 02:43 PM
aaroncorvette
Thanks Jason Staley, Keisler said they only do a 3" ali prop, so i'll stick with the steel one.
To Aluminium prop, any good?
