Door To Door Front End
Old Feb 8, 2009 | 02:37 PM
ATHANASE's Avatar
ATHANASE
Default Door To Door Front End
I am about to entirely rebuild the front part of the car (1971) from the windshield to the front bumber. I plan on buying a complete door-to-door front end, but I wonder what product to buy and where from.
I would welcome any advice on my option and about these 2 products from Eckler's (URL's below). What does justify the price difference ?
Jig-Fit Front End, Press Molded, Door To Door
http://www.ecklers.com/product.asp?p...7&dept_id=1427
and
Door To Door Front End, Stock Design
http://www.ecklers.com/product.asp?p...0&dept_id=1430
Old Feb 8, 2009 | 04:55 PM
Alan 71's Avatar
Alan 71
Hi A,
The expensive clip is made the way the factory clip was, from various pieces joined by bonding strips.
The lower priced clip is one large molded piece.
If you want to keep your 71 as original as possible the expensive clip helps to do that. For many people installing the one piece clip lowers the value of the car.
Is your existing fiberglass so bad that it can't be saved?
Regards,
Alan
Old Feb 8, 2009 | 06:01 PM
jnb5101's Avatar
jnb5101
two things to consider, the one piece fronts are HUGE. be sure you will have the room to set it aside while you are fitting it. also, because of the size(not weight-they only weigh about 50 pounds) two people are needed to place and remove it. and you will be putting it on and taking it off many times before it's ready to bond. i've done a eckler's one piece and it fits and looks good. i just finished doing a piece by piece build up with the individual parts. it was easier than the one piece because there's fewer things to adjust on each individual piece than the whole front end.
Old Feb 9, 2009 | 01:03 PM
ATHANASE's Avatar
ATHANASE
Regards,
Alan
Well, it's entirely crashed, as a matter of fact. Got to redo it all.
Old Feb 9, 2009 | 02:37 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
from what i got from the two links is that the more expensive one comes with the inner skirts but i dont see any mention of the inner skirts on the cheaper one.
Old Feb 9, 2009 | 03:14 PM
wombvette's Avatar
wombvette
No skirts on the one piece. You will have to buy and install them.
Old Feb 10, 2009 | 02:25 PM
ATHANASE's Avatar
ATHANASE
Yes, if you add all the stuff that is not included with the cheaper one (inner skirts, header bar, nose bar) it is still $1900 cheaper.
I believe the finish is not the same at all.
Old Feb 10, 2009 | 03:12 PM
Alan 71's Avatar
Alan 71
Hi A,
The one piece front clip is cheaper for many reasons.
It changes the value of the car until someone decides to put the proper pieces back on.
What is the goal for this car while you own it? That should help you decide where to put the money.
Regards,
Alan
To Door To Door Front End
