Rear Spring Bolt Kit Question
Grease them very well or you'll get lots of squeeking.
Also have it aligned after changing the height using the bolts.
"So?", or "WT#?", you might ask. IMCO, as long as your rear toe is correct now and you don't drastically alter your height (i.e. slam your ride), you most likely needn't worry about checking/adjusting anything other than possibly the rear camber. To see if and how much ride height may be changed, I suggest checking the "D" height spec (see below) before and after any work, making sure the suspension is fully settled between each measurement. Yes, installing new strut rods may change your camber.
Of course, if you're not sure of your current alignment or DIY'ing any of this makes you uncomfortable, by all means enlist an alignment shop known to be proficient with C2/C3's. But, FWIW, it's a good idea to learn at least a little about these matters first; making you a more difficult mark for either Bubba or anyone else who may be looking to fleece another unwary Vette owner.
