4-speed experts needed
Old Feb 1, 2009 | 05:00 PM
tak82's Avatar
tak82
Default 4-speed experts needed
I have a 4-speed that is vibrating in 1-3 but not in 4th. It's more in 2-3. The tranny was rebuilt with all new bearings but I can't recall if I replaced the front bearing on the main shaft. The gears are all good, new syncros, the shafts weren't worn. The tailshaft had a new bushing installed, new crank pilot bushing. If you pick the tranny up by the front shaft and tail housing, there is some movement in the front shaft. I don't know if this is o.k. or not and also besides the vibration it is pretty noisy in those gears. I've put maybe 50-100 miles since rebuilt. I thought I'ld ask for some ideas before I rip it all apart. Could it be the front shaft bearing vibrating 1-3 but not 4?
Old Feb 1, 2009 | 05:46 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I think it is something in the countershaft. 4th is 1 to 1 and the countershaft doesn't come into play.
Old Feb 1, 2009 | 06:31 PM
tak82's Avatar
tak82
The counter shaft was replaced, not saying that's not it though. I'm wondering if anyone else has ever encountered it and what there problem was.
Old Feb 1, 2009 | 06:42 PM
wills670's Avatar
wills670
Does shifting hard or NICE and soft end with the same result?
I had a chevyII that was doing about the same thing and the pilot bearing was wore out. When you shifted it hard the input shaft would be mis-aligned and viberated like crazy. When you paused between shifts and give the clutch disk time to center itself the vibration went away.
Old Feb 1, 2009 | 07:01 PM
tak82's Avatar
tak82
No. Drive it like your grandma or beat the pi** out of it, no difference. The pilot bushing is new and the shaft has a good fit in it.(checked the bushing fit before install). What gets me is the counter shaft is good, the bearing are new and the gears are great. The countershaft is tight in the case. I'm hoping someone will say xxxxx will cause this, before I start quessing on what to start replacing. I will be tearing the tranning completely apart tommorrow and really inspect it.
Old Feb 1, 2009 | 07:15 PM
wills670's Avatar
wills670
I think there were two different size cluster shafts used in muncie trans. I seem to recall one was 7/8 shaft and the other was 15/16.
Just tossing out ideas.
Old Feb 1, 2009 | 08:46 PM
vettesbydesign's Avatar
vettesbydesign
Most muncies have alittle play on the input,and that is okay,but it depends on what "alittle" is.
The shafts were 7/8s for the earlier,then they all went to one inch.That shouldn't be it.
Old Feb 1, 2009 | 08:48 PM
tak82's Avatar
tak82
I'm thinking it's in the coutershaft or gears, but not sure where. Has anyone had this happen to them and why ?
To 4-speed experts needed
