rear main seal
Old Feb 2, 2009 | 05:22 PM
Al Davis's Avatar
Al Davis
Default rear main seal
I am getting a 1987 or later 350 4 bolt stroker 383 w/ a one piece rear main and roller cam ready. I seen the adapters on the internet. My question is, does chevy machine the block, drill and tap the screw holes and fit the block w/ this adapter like seal from the factory?
Old Feb 2, 2009 | 05:48 PM
Durango_Boy's Avatar
Durango_Boy
I don't understand your question. Are you saying that you want to convert your 1 piece seal block to a 2 piece design so you can change the seal with the transmission in place?
Old Feb 2, 2009 | 06:17 PM
GDaina's Avatar
GDaina
You need the adapter if you are using a block that is made for the single seal with a crank that requires the two seals....no machining is required as the adapter fits in the block..
Old Feb 2, 2009 | 09:25 PM
Al Davis's Avatar
Al Davis
Default rear main
What I want to say is, do the 1987 and newer blocks w/ a one piece rear main seal come new from Chevy w/ the adapter type seal already installed for the one piece main seal?
Old Feb 2, 2009 | 09:32 PM
Durango_Boy
You won't need any adapters or anything like that. The block is a 1 piece rear main seal block so all included hardware and seal is designed for that block. There's a ring that houses the seal, that bolts to the block over the back of the crank. It's all designed that way stock so you won't have to worry with adapters or machining.
Old Feb 2, 2009 | 09:45 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
DB He wants to use his 350 crank in this new block. Object is to internally balance using his existing internals and later be able to buy an internally balanced 2 piece style 383 aftermarket crank and upgrade to roller cam. Saves having to change flywheel and balancer and the internal balance stroker crank is cheaper in 2 piece than one piece.
Al, all you need is the adapter. The newer block will accept the adapter and you use all your existing hardware. Good move going to this block with your present and future plans.
Old Feb 2, 2009 | 09:48 PM
Durango_Boy
Wow I guess I totally missed the old crank part of the question. That would have made a lot more sense to me and I'm sorry I misunderstood.
Old Feb 3, 2009 | 12:26 AM
GDaina's Avatar
GDaina
You use the old style, two piece seal with the adapter...
Old Feb 3, 2009 | 09:11 AM
63mako's Avatar
63mako
No, you just missed his previous thread when he was discussing boring his old block .060 over. Guess he decided to go with the new block.
To rear main seal
