Self exciting regulator for alternator
Old Feb 3, 2009 | 04:45 PM
SMH's Avatar
SMH
Default Self exciting regulator for alternator
Anyone know the part number for the self exciting regulator? I have a 100amp SI type alternator and trying to explain it to parts store has been a nightmare. My one wire alt is putting out 16.7 volts I need a new regulator quick before I mess something up.
Old Feb 3, 2009 | 06:20 PM
Ironcross's Avatar
Ironcross
The parts to make it a 1 wire is in the alternator. All you need is to replace the regulator in the alternator...
Old Feb 3, 2009 | 07:55 PM
SMH's Avatar
SMH
Thats what I need. I already have a one wire alternator and the regulator is bad. They have a self exciting regulator in them. I need the part number on the regulator so I can get a new one.
Old Feb 3, 2009 | 08:06 PM
bluthundr's Avatar
bluthundr
This guy? http://www.autozone.com/Ntt,VR723/sh...allResults.htm
Old Feb 3, 2009 | 08:17 PM
SMH's Avatar
SMH
Originally Posted by bluthundr
OK thanks is this the self exciting regulator? Or is it just the regular one?
Old Feb 3, 2009 | 08:26 PM
SMH's Avatar
SMH
I looked it up and it looks like this is the stock replacement.
Old Feb 3, 2009 | 08:58 PM
SMH's Avatar
SMH
Like this one. They cant cross refrence this number though.
http://195.125.241.148/cgi-win/product.exe?D10SE12
Old Feb 3, 2009 | 09:32 PM
Ironcross's Avatar
Ironcross
All you need is a stock regulator. A one wire is accomplished by the plug that full fields the regulator thereby making it a one wire Alt...Overcharging indicates is a bad regulator . Something you allready know. To fix it, put a regulator in it.
Old Feb 3, 2009 | 09:48 PM
SMH's Avatar
SMH
I will try but I am reading about a special self exciting regulator other places. I will try a regular replacement regulator and see if it works.
http://www.classictruckshop.com/one_wire.php
http://store.summitracing.com/partde...50+4294847188+
http://www.alternatorkit.com/one_wire_kit.html
Old Feb 5, 2009 | 02:16 PM
SMH's Avatar
SMH
The stock one did not work but I found what I needed. It has to be a self exciting regulator.
Here are some part numbers if anyone is interested.
Transpo #D10SE12
ACE # VR1770SE
To Self exciting regulator for alternator
