Wimpy azz Horn
Old Feb 6, 2009 | 05:55 PM
tomard's Avatar
tomard
No cracks that I can find on the Hi-Note horn! I am going to go junkyard scavaging tomorrow .... there were a bunch of mid-late 80's caddy's last time I was there so I will grab a couple off of them and try them out. I can get them for a couple bux, so no harm if they are not up to snuff. If that is not going to work, then I will get a new set.
Old Feb 7, 2009 | 08:41 PM
tomard's Avatar
tomard
Alight - took Gene's advice (mrvette) and hit the junkyard ..... got what looks as two mid-90s caddy horns (A & F notes stamped right on back). Then two from a 94 firebird that has nice weather resistant connectors all for less than $10 ..... I am going to hook up to first then maybe another for effect A couple of final questions, that someone can help me with:
What purpose is the relay for on the horn circuit ???
Would ADDITIONAL ADDED horn make it louder or not ???
Old Feb 7, 2009 | 09:05 PM
mrvette's Avatar
mrvette
The TYPICAL GM horn from some time ago had the hot wire interrupted by the horn relay, the ground was supplied by the mounting bolt....IF you find 2 wires....one has to be grounded, the other fed with the same 12 volt wire as per stock....you can branch off you vette stock wire and feed 3-4 of those horns....be a horney as you want, and yes, they do get longer and louder the more you honk.....
Old Feb 7, 2009 | 09:06 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
horn?
We don't need no stinkin' horn.
Old Feb 8, 2009 | 06:59 PM
tomard's Avatar
tomard
Default Success
Jeez - I have three horns now and I think I am walking more upright with a strut in my step
Ended up with stock LOW note (top horn), and the two horns from 94 Firebird (had better brackets that were easier to fit than the caddy ones) and the weather-proof connectors.
The way it WAS sounding was "the Beav" trying to perform a Tarzan yell while going through puberty ..... NOW it is the GODFATHER
Thanks everyone - learned about horns!
Old Feb 8, 2009 | 09:52 PM
mrvette's Avatar
mrvette
Hey, Us Horney toads know how to honk when we get on it.....
Old Feb 8, 2009 | 11:45 PM
Dante7's Avatar
Dante7
If your going to go through all that trouble to change to a none stock horn why not have some fun with it and just buy a set of air horns that you can have some fun with... They are pretty simple to install usually come with a small airtank you can hide just about anywhere and you just need to run a 12 volt wire to the battery to run the compressor... You could really scare some old buick then..
Old Feb 9, 2009 | 12:22 PM
tomard's Avatar
tomard
Wasn't any trouble - kind of fun actually! Just another little thing to mess with ......
Old Feb 16, 2009 | 10:14 AM
troy1m's Avatar
troy1m
a relay is for remote operation of any device. it's like an electric switch. Instead of running bigger wire to the switch, you use a relay. your starter solenoid acts as a relay, So it isn't necessary to run those big cables from your battery to the ignition switch. your headlights have a relay, your house thermostat operates a relay.
Old Feb 16, 2009 | 04:55 PM
Young69Owner's Avatar
Young69Owner
My '69's horn works, but it would be neat to adjust it. I think I had two and I think that was an option. My car had the alarm and I may restore it at some point. So, anyways, tell me about using the screw to adjust the horn. If I adjust the frequency, will it appear louder?
