What would you do with $2000???
Old Jan 23, 2002 | 05:18 AM
RaC3R's Avatar
RaC3R
Default What would you do with $2000???
Within the next few weeks I'll be buying a C3, probably a mid-late 70's model with the stock L82 :).
I eventually want a high horsepower fuel injected daily driver - I've been told that a TPI setup and L82 build-up is cheaper and more productive than an LT1 swap.Concentrating solely on performance - if you had $2000 to spend what would you buy and why?
Old Jan 23, 2002 | 05:28 AM
mrvette's Avatar
mrvette
Default Re: What would you do with $2000??? (RaC3R)
I have to assume you are a 'roll your own' kind of guy, like myself....
and can doyour own wiring/computer install, top end mechanicals, etc...
and maybe can change the tranny to an O/drive unit....
those are the main things to do to improve performance and fuel economy...
the injection alone is certainly worth the troubles, the o/drive is maybe not depending on amount/type of driving....
GENE
Old Jan 23, 2002 | 05:54 AM
RaC3R's Avatar
RaC3R
Default Re: What would you do with $2000??? (mrvette)
I'm flattered Gene but I can't even change my own oil :( I am learning tho... :D But most of my friends in my Z28 club know about SBC's so I shouldn't have too many problems with the labour aspect...
Old Jan 23, 2002 | 06:40 AM
Larry B.'s Avatar
Larry B.
If i had an extra 2K I'd send it to LARS for all of the help he has given the forum guys. :lol: :jester :jester :jester :jester :jester :jester
Old Jan 23, 2002 | 07:16 AM
BLT-71's Avatar
BLT-71
2000 eh!
Well if my engine wasn't built for the performance I wanted it would all go there.
But for me since I just finished the rebuild. I would purchase an Edelbrock fuel injection system and have a hot rod with good manners.
Old Jan 23, 2002 | 08:20 AM
Corvettes White's Avatar
Corvettes White
Sorry, but if I had an extra $2000 and was buying an old Vette, I save the money to fix all the little things that need to be fixed first. We bought a '79 a few years back. Burned thru 2k very quickily. Still have the car and love it.
George
Old Jan 23, 2002 | 09:33 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: What would you do with $2000??? (999)
I'd buy a Scat stroker crank and 64cc aluminum heads for my 350 rebuild.
[Modified by 1970 Stingray, 8:33 AM 1/23/2002]
Old Jan 23, 2002 | 09:37 AM
Edzred72's Avatar
Edzred72
Carb, intake, heads, headers, and if any cash was left... lots of RUM :cheers: :cheers: :cheers: :cheers: :cheers:
Old Jan 23, 2002 | 09:43 AM
ylose's Avatar
ylose
Default Re: What would you do with $2000??? (Silvr77)
:lol: :lol: :lol: :lol:
what he said....except the RUM....(yuck)...actually I just redid my upper half of my engine...see my SIG for details and pictures.
Old Jan 23, 2002 | 09:46 AM
Bill Meyer's Avatar
Bill Meyer
Assuming my wife doesn't continue to encourage me to seel for a more spacious car to transport the triplets plus 2 more
I would use the $2000.00 for mid - 60s sidepipes and headers for my '77. :D
Old Jan 23, 2002 | 10:02 AM
mrvette's Avatar
mrvette
Well that makes it sort of rough, unless you get a wiring harness and maybe even a commercial DPFI unit....Edel, etc....
GENE
Old Jan 23, 2002 | 10:03 AM
Edzred72's Avatar
Edzred72
Default Re: What would you do with $2000??? (ylose)
Cruise with the "General" but sail with the "Captain". Morgan that is!!!
Old Jan 23, 2002 | 10:16 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Installed overdrive, 3.70 gears, and hooker sidepipes. I think I could do it for $2000.00. I already have the tranny!
Old Jan 23, 2002 | 10:39 AM
Alwyn678's Avatar
Alwyn678
Default Re: What would you do with $2000??? (1970 Stingray)
I would spend it on a 6 speed
Old Jan 23, 2002 | 11:42 AM
terryrudy's Avatar
terryrudy
I agree, hold onto it for a few months and see what breaks. It would *really* suck to buy some killer heads, fuel injection, etc, and then be sidelined a week later if the radiator goes or a caliper develops a leak and you need to redo whole brake system. :)
-terry
Old Jan 23, 2002 | 12:20 PM
fastback79's Avatar
fastback79
I would go with a dual exhaust and a fiberglass rear leaf sprng first. But most importantly, I would leave some of that money in the bank just in case something goes wrong with the car. I have ha my79 for ten years, and do know that it is important to make sure the car has all the mechanicals (brakes, transmission, rag-joint, halfshafts,shims, etc.. in good shape before you start thinking about performance upgrades or cosmetic upgrades.
Old Jan 23, 2002 | 01:08 PM
JohnS_77's Avatar
JohnS_77
:yesnod:
"Set sail with Captain Morgan, and never leave dry land..." :cheers:
I would work on "refreshing" my rear suspension: Trailing arms, rear spring, shocks, u-joints, rear end.
To What would you do with $2000???
Old Jan 23, 2002 | 02:29 PM
ylose's Avatar
ylose
ahaha...Silvr77 your breathe would make me drunk !!! :lol: :lol: :lol:
(I am a non-drinker so a sip would intoxicate me...errr...maybe not...i weigh in at 200 pounds of beef.... :yesnod: I workout too much to drink) :D
back to the original question.....if after you waited all looks good...
and you still want more performance out of the ENGINE...not the car...
do cam,heads,intake,exhaust...using all of the $2000....
if you want to launch out of hole and like the engine as is
then get gears and exhaust and a higher stall and have $1000 left over for maybe some heads or interior work....
if you want better gas mileage and better out of the hole !
then put in an overdrive tranny and better gears...for all of the $2000
if everything falls apart after a month of driving it....then get a loan,
cause the $2000 aint enough to fix it all !!! :eek:
Old Jan 23, 2002 | 02:59 PM
Lohkay's Avatar
Lohkay
2000$? Lots of BEER for the long weekends I have to work on it. :cheers:
Old Jan 23, 2002 | 03:30 PM
tnt76vette's Avatar
tnt76vette
Default Re: What would you do with $2000??? (Lohkay)
Gotta agree w/999 & terryrudy.....make SURE the thing is safe first, cause you can easily suck up $2K if it isnt. If all is well, then have at it. All ya gotta do is let your wallet/seat of pants ratio be your guide...... :jester
