ZZ454 engine install help
Old Feb 6, 2009 | 11:07 PM
lfgmike's Avatar
lfgmike
Default ZZ454 engine install help
Would like some feedback on the GM Performance motor ZZ454. I have a 69 Vette coupe 427 4bbl 4spd(numbers match). I wanted more power, so figured I'd preserve the original motor and drop on the new motor. Got a price of $6000 for the ZZ454 brand new, looking for some guidance. Thanks!
Old Feb 6, 2009 | 11:18 PM
DZRick's Avatar
DZRick
I can't help you but I've got a friend that is looking for a big block for his vette and would appreciate a link to the one your looking at.
Old Feb 6, 2009 | 11:27 PM
lfgmike's Avatar
lfgmike
yeah sure; http://www.gmperformanceparts.com/Pa...l.jsp?engine=3
just pick the motor you want and call your local Chevy dealer. I think I'm using Arlington Heights Chevy in Illinois. Friend connection for me.
Old Feb 7, 2009 | 12:08 AM
GDaina's Avatar
GDaina
www.paceparts.com these guys have decent prices, also check out summit
Old Feb 7, 2009 | 08:03 AM
lfgmike's Avatar
lfgmike
thanks. I just checked out the ZZ454 price- they're right there!!
Old Feb 7, 2009 | 12:30 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
I dunno.... You pull a 427 you should put a 427 back in
ESPECIALLY the anniversary all aluminum 427
Go cheap and you'll regret it later
Old Feb 7, 2009 | 12:36 PM
3JsVette's Avatar
3JsVette
There is very encouraging article in the March 2009 issue of Super Chevy. On the Dyno the motor made 490 horsepower and 520 lbs of torque. Not bad considering it's rated a 440 horsepower. It sounds like you would be getting exactly what you're looking for.
Old Feb 7, 2009 | 02:44 PM
lfgmike's Avatar
lfgmike
You make total sense, but I'm dealing with a budget. The anniv 427 is $23,000!!! The ZZ454 is a fraction of that. If I go with the ZZ427, its more $ and less power.
Old Feb 7, 2009 | 02:48 PM
lfgmike's Avatar
lfgmike
That's what I heard! I don't "baby" my car either, I'm kinda hard on it, and I would be an idiot to wreck the original block. Pay the extra dough, put in a solid motor, put the orig motor in storage, and have fun...
Old Feb 7, 2009 | 03:27 PM
Kfmorgan's Avatar
Kfmorgan
I put the ZZ454 in my 73 about 18 months ago. As one of the responders said, its got plenty of power right out of the box. Not being satisfied with its advertised power, I did some modifications to it, before installing it, along with a TKO 600. You will definitely be satisfied with that engine.
Please feel free to E-mail me about any specific questions that you have regarding the installation. I'd be happy to share any knowledge that I gained during the process.
Good Luck!
Old Feb 7, 2009 | 09:52 PM
lfgmike's Avatar
lfgmike
Big help-thanks. What is the TKO 600, and do you have any advice on carb/ignition/ set-up? I think we are very much alike, wanting a little bit more than what is listed on the specs. I also have the '69 side pipe, but was thinking of going with the Hooker chrome(4 into 1) side pipe. I need headers, so thought this would be a good choice.
Old Feb 8, 2009 | 10:43 AM
GDaina's Avatar
GDaina
Forget the chrome....they are expensive, and they rust...chrome on those headers is flash chrome and before you know it you will be faced with rust where the four pipes join the collector...
Old Feb 8, 2009 | 03:57 PM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
You're gonna love it!!! I put a tach drive HEI dist and an 850 dual feed Holley on it.
No it'll never be a 7500rpm screamer out of the crate...but it makes great low end power, and plenty of top end to bring a to your face!!!
Old Feb 8, 2009 | 04:15 PM
Kfmorgan's Avatar
Kfmorgan
The TKO 600 is Keisler's Tremec 5 speed overdrive transmission.
I am using an 850 double pumper ProForm body on an Edelbrock TM-1 Tarantula single plane intake. I have port matched the manifold to the heads. I am using a fairly agressive roller camshaft along with some roller rockers. If you plan on using the engine as it comes out of the box, you should be fine with the intake that comes with the engine. A good second choice would be Edelbrock's Performer RPM dual plane intake. A good 750 double pumper carb would work fine. I have been using a Mallory Unilite distributor for years with no problems. I am also adding a Summit CD box to the system when I get it ready in the spring. I have been using the Hooker Black side pipes since the car was new. (Second Set) I agree that you should stay away from the chrome. What ever exhaust that you do use, make sure that you fit it to the heads while the engine is out and on the engine stand. you don't want to be trying to fit and grind the flanges while the engine is in the car. Also make sure that you can get a wrench on all the plugs. You may have to massage a tube or two so that the socket will slide onto the plug.
Again, good luck with your project.
Old Feb 9, 2009 | 10:49 AM
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
Some of the guys over at the Chevelles forum are pretty big on this deal: http://cgi.ebay.com/ebaymotors/454-5...Q5fAccessories
I personally don't know anything about the seller but the h.p. numbers sound good for the money.
Old Feb 10, 2009 | 08:42 AM
lfgmike's Avatar
lfgmike
Default Zz454
Thanks for the thought, but I checked out that engine, and seems like maybe too much power for me. Looks like a great price as well.
I just started using this Corvette forum, and I am suprised how cool this forum is! I REALLY appreciate the advice from all you guys.
Old Feb 13, 2009 | 07:47 AM
Ray Y's Avatar
Ray Y
Come on, bite the big bullet, go for the new GMPP LS9 crate motor. Known as the LSX 454 rated at 620 HP with 590 ft lbs torque. Still an iron block. GM part # 19166972. Nice article on it in the April '09 issue of Vette magazine.
I know where I'd spend my TARP fund stimulus....
To ZZ454 engine install help
Old Feb 13, 2009 | 02:25 PM
ToniH's Avatar
ToniH
Aren't all old 427's internally balanced and 454's externally balanced? What about ZZ454?
And does it matter if you replace internally balanced motor with external balance motor? What parts needs to be changed? Balancer, flywheel/flexplate?
Old Feb 13, 2009 | 03:52 PM
midyearvette's Avatar
midyearvette
you will need to buy the flywheel from gm that is specific to the one piece seal zz 454. also the clutch bracket they have available. watch for ground clearance with the new oil pan because it is a 6 qt. instead of 5 and your power steering cylinder may rub the pan on left turns........
Old Feb 14, 2009 | 06:37 PM
FlyViper's Avatar
FlyViper
Will a '71 stock rearend and M-21 trans hold up to a stock ZZ454 with normal street tires? I definitely want to put in a TKO-600 at some point, but want to know if putting a ZZ454 in my car w/ the stock driveline is a bad idea. I won't put slicks on the car and I'm not taking it to the track...it will be purely driven on the street. I figure if I "ask too much," the tires are just going to spin anyways, thus not catching and snapping the diff in half. Is this a correct/safe assumption or can I not put this engine in my car until I get a TKO? Thanks guys!
