oil pressure sender
Old Feb 7, 2009 | 12:53 PM
painterman52's Avatar
painterman52
Default oil pressure sender
My oil pressure gauge has been acting very erratic, needle bouncing all over. I replaced the oil pressure sender and now the needle is pegged on the high side. The new one has a much larger inlet for the oil than the old one. Would this cause a misreading?
Old Feb 7, 2009 | 01:20 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Did you use teflon tape on the threads? Don't!
The unit is self grounding and must have contact with the engine block.
Old Feb 7, 2009 | 01:39 PM
SIXFOOTER's Avatar
SIXFOOTER
Sounds like they gave you the wrong unit. If the old one was erratic it may have just been the connector on the wire. The new one might be just a oilpressure warning switch instead of a sensor. Put the old one back in and make sure the wire on the unit is secure. You can use teflon tape but only 1 wrap. The sender threads will cut thru the tape and push it into the voids between the threads. If you put on 2 or 3 wraps it might not and can isolate the ground connection preventing the gauge from working at all.
Old Feb 7, 2009 | 04:09 PM
painterman52
I got the one for a light. Thanks
Old Feb 8, 2009 | 04:39 PM
markdtn's Avatar
markdtn
Get a new parts store. C3s never had just a light.
To oil pressure sender
