low oil pressure
Old Feb 8, 2009 | 01:43 PM
painterman52's Avatar
painterman52
Default low oil pressure
I have a 383, 2 years old with about 10000 miles on it. It runs real good. When new at startup I had 75 to 80#`s of pressure then it would go to 55 to 60. Last year it seemed to go down slightly but steadily. Now at startup I have 40# and it goes down to 20 at cruise and 15 at idle. I have a high volume oil pump and I`ve used different oil weights. Right now I have rotella t 5/40 full synthetic. I live in N. Il. so it is cold. Any ideas why such low pressure, how concerned should I be.
Old Feb 8, 2009 | 06:33 PM
KevinZ's Avatar
KevinZ
To Keep it simple, try a new oil pressure sending unit.
BUT!!! If you can, place a mechanical Gage in that port to get an accurate reading.
You can buy a Gage and install the adapter and check without installing as a permanent fixture in the car and verify the oil pressure.
If the pressure is ok by changing the sender, Job is done
If pressure is good with mechanical gage, and still bad by sending unit, electrical troubleshooting begins.
Keep us posted!!!
Old Feb 9, 2009 | 07:04 AM
painterman52
I installed a new sender a couple of days ago. The old one was erratic and bouncing around. They both read the same low pressure. I needed a new sender beause the new one is not erratic but it is not my problem.
Old Feb 9, 2009 | 08:25 AM
BLOCKMAN's Avatar
BLOCKMAN
If the gauges are right it sounds like your have some bearing issues going on or clearance issues.
Keep us posted on your findings
Old Feb 9, 2009 | 10:10 AM
7T1vette's Avatar
7T1vette
At least, it's time to check out the condition of a couple of crank bearings. If all is good, check the pump & regulator spring while you have the pan off. Hopefully, it is just a sender/guage problem; if it turns out to be bearing wear, it's good to catch it before the engine fails.
Old Feb 9, 2009 | 10:20 AM
Jims66's Avatar
Jims66
Before you drop the oil pan I'd do a quick oil change and pour some of the used oil through a coffee filter to check if there are any metal shavings in it. Might want to cut the filter in half as well. It sounds like a bearing may be going bad. Just my 2cents..............
Old Feb 9, 2009 | 03:57 PM
painterman52
I`m on my way out to change the oil. I have a magnetic oil plug. Will that tell me if any metal is in the oil or do I need to cut open the filter?
Old Feb 10, 2009 | 01:09 AM
7T1vette's Avatar
7T1vette
No....because the surface of the bearings is not magnetic. If your engine is wearing hard steel parts, it is in even more trouble. You can drain the oil and stir it up (hard particles sink to the bottom pretty quickly), then put some on a glass slide or in a thin bottle. Shine a strong light through it and see if there are any reflective particles in the oil. If so, you [likely] have a problem and need to check those bearings.
Old Feb 10, 2009 | 01:36 AM
BLOCKMAN's Avatar
BLOCKMAN
If your oil filter bypass was not pluged there is a good chance if there was debris going through the oil pump it most likly pushed everything through to the bearings as well.
Old Feb 10, 2009 | 01:58 AM
noonie's Avatar
noonie
If you are really concerned send an oil sample to a oil lab and they can tell you what exactly has worn, of anything. Around 20 bucks.
Also the oil pump relief could be failing causing a lower indicated pressure.
Old Feb 10, 2009 | 07:16 AM
painterman52
After changing the oil with 15/40 ci4 I now have 15-20# at idle and 40-45 at 2500 rpm. The biggest problem may have been the way the sender was installed. When the 383 went in the hole above the oil filter appears sealed . The sender I had didn`t fit near the distributor. So my friend aka bubba put in a straight adapter then a 90 then a an6 90 then a 18" piece of hose then a 90 then the sender. I removed all that and installed the proper sender.
To low oil pressure
