installing edl heads help,,asap
in process of installing used edlbrock rpm 60999 64cc/1.60/2.02/170 head on my l48 i need to know :
-as they are used and face was less as per the heads shop who cheked them the surfice is less half mm less ( 05mm)
-what gasket shuld i use ?? fp or gm
-will the stock head bolts and rocker arm & pushrods work?
tks
tks
http://www.edelbrock.com/automotive_...6000/60999.pdf
The fact that the heads have been surfaced makes no difference. 0.5mm = 20 thou, no biggie.
You need to carefully inspect the deck of the block. Makes sure the surface is good and the deck is not warped (lay a straight edge across it).
the block is standrard never been toched surface is good and smoth ,,nothing was wrong
with the old heads just want to get some mild hp i got the fp head gasket set i think
friend of mine advice that i dont need the fp 1003 unless iam using netro or track race
thks for the feed back mates
