Crossfire to Carb Progress
Old Feb 9, 2009 | 03:00 AM
shoeitime's Avatar
shoeitime
Cruising
Default Crossfire to Carb Progress
Hello there everybody. I am just posting this to update on the progress on my CFI to Carb conversion. And will like to thank everybody that has helped me so far. Ok so far I have replaced the engine with a new 290HP GM crate engine. I installed some of the wiring for the lock up kit from Bowtie overdrive the one that comes with the brake switch.http://www.bowtieoverdrives.com/cata...php?ITEMID=332
I still have to remove all of the wiring from the CFI and figure out what goes where as far as Vacuum lines and stuff. I will update as I go thanks.
NANCY
Part list that I have recived:
MSD-35599 WIRE SET
MSD 8361 PRO BILLET DISTRIBUTOR w/vac advance
MSD 6200 IGNITION BOX
MSD-8207 STREET BLASTER SS COIL/E-CORE
NAL-12499529 GMPP 350 LONG BLOCK 290/32
HLY-0-80670 CARBURETOR 670CFM
ARP-430-3102 MOTOR MOUNT BOLT KIT STAINLESS
EDL-2101 MANIFOLD PERFORMER SBC NON-EGR
EDL-7201 INTAKE GASKET
EDL-8504 BOLT KIT INTAKE MANIFOLD
FEL-35062 GASKET
GTR-61047 CURVED RADIATOR HOSE
GTR-61163 CURVED RADIATOR HOSE
HED-68300 (CA) HEADER
HLY-20-121 700R4 KICKDOWN BRACKET
HLY-20-95 KICKDOWN BRACKET TH-700R4/4L60
MAA-4309 FUEL REGULATOR THREE PORT COMP
MRG-1272 OIL FILTER ADAPTER
PTP-7-504 GM MTR MNT TYPE A SHORT PAIR
SUM-161358 BALANCER OEM 350 8 INCH
SUM-371101 ALUM 90 DEG SWIVEL WATERNECK
SUM-G100SFI FLEXPLATE CHEV SFI 168 TOOTH
SUM-G1438 OIL PRESSURE SHUT-OFF SWITCH
SUM-G1571HS SHRT WATER PMP BLT KIT HEX SBC
Old Feb 9, 2009 | 03:36 AM
gingerbreadman1977's Avatar
gingerbreadman1977
great before and after shots. what an awesome change .. looks like that beast has seen some snow!! but now all it wants to do is get out and shine.
Old Feb 10, 2009 | 08:40 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Hey girlfriend!
Looking great!
Words of wisdom;
Coat headers
Wrap headers
Coat your intake with clear or paint
Add manual valve for heater, lowes $10
I'll send some pics of relay location later.
Best!
tt
BTW, 2nd place
Old Feb 10, 2009 | 11:24 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
One More;
Trying to save you and the husband alot of back and forth work.
When you get in around the front end, and start replacing bushings and stuff. If you want to REALLY make your Vette really sweet with a killer stance, and for the budget minded, cut one coil on the front springs, just one. Rear is lowered 1 1/2 inches as well.
Old Feb 10, 2009 | 05:07 PM
shoeitime's Avatar
shoeitime
Cruising
OMG!! Thats a buueetifull call!! Love the way the paint shines with the lighting Should of won First Place. Ya I was thinking about wraping the headers but was worried that the wrap might burn off or something LOL. I am also thinking about pluging the intake and waterpump heater outlets since it gets really Hot here in san antonio and I doubt we will use the car if it gets too cold. Do I have to plug anything else to remove the heater?
Old Feb 10, 2009 | 08:05 PM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
It is no big deal to leave the hoses in place and just add a manual valve. You will find yourself one of these days out and it will get cool and you will wish you could just turn a valve and have heat, been there done that. The stock and aftermarket vacuum valves seem to fail often so most folks just add a manual. This one fit perfect, Lowes, 3/4 or 5/8 can't remember, $10.
Old Feb 11, 2009 | 04:34 AM
shoeitime's Avatar
shoeitime
Cruising
Wow that looks easy and you also gave me an Idea of doing something similar to the fuel line. There has been ALOT of car boost and wanted to add something like that as a anti theft device.
Old Feb 11, 2009 | 09:48 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Hope this helps too. This is located in battery area, between compartments.
To Crossfire to Carb Progress
