Door lock question.
1970 Corvette, which way is the key supposed to go into the door lock? With the flat edge up or down?
I know it sounds like a stupid question, but I looked in my AIM and chassis service manual and neither one gave a definitive answer. My neighbor and I are also split on the issue. Hopefully you guys can resolve this for me.
In frustration, I ended up taking the lock cylinder out to see if I could figure out what was wrong with it, but when holding it in my hand, it seemed to work absolutely perfectly. A few hours (and a couple of beers) later, it dawned on me. The car essentially came from a paint shop to me, and they must have taken the door locks out to do the paint. My guess is that when they put the locks back in, they switched them, such that I was holding a perfectly good driver's side cylinder that wasn't working the lock because it was installed upside down on the passenger's side.
If anyone thinks I have dorked this up in any way, please let me know.
Thanks,
PK
Actually, the whole assembly is surprisingly NOT corroded. The cylinder works perfectly in my hand. The lock operates smoothly from the inside **** now that I have greased all of the linkage inside the door. My garage being what it is, I can only open one door fully, which is why I started on the passenger side. I have the same problems on the driver's side. So, once I concluded the locks were installed backwards, I put the rest of the car back together so I can pull the car out and turn it around to work on the other side. I am hoping to do this on Saturday, and start reconditioning the driver's door.
Of course, now that I am hoping to have access to the driver's side in the garage, I am planning on removing the driver's seat because it needs new bolts. Then I want to get under the dash while the seat is out and replace the bad neutral safety switch. Then, when I re-install the seat, I want to try putting a few washers under the transmission side of the seat rails because the seat tilts uncomfortably to the right.......
Thanks,
PK
Flat side up, flat side up, flat side ...
Saturday, I started the car to turn it around in the garage to get at the driver's door. She cranked right up after not starting for almost 3 months, so I couldn't help but go for a short ride, first ride of 2009!!!
Anyway, got the car turned around and with a little help from my daughter's significantly smaller but not as strong hands, we got the lock cylinder that was in the passenger door installed in the driver door. Now, the key goes in flat side up, and the door lock works flawlessly!
So, the car is in pieces (seats out, still don't have the passenger door back together), and my suspicion last year of a small fuel leak has turned into an obvious fuel leak (and the leaked fuel is landing on the exhaust
), so it will be a while until the next ride. Spring is around the corner though, gotta find the time in the garage if we want to be riding in style!!!
All the
