VBP #420 spring question
Old Feb 9, 2009 | 10:30 PM
White 68's Avatar
White 68
Default VBP #420 spring question
Just bought a VBP #420 rear spring 1/2 " shorter on each end from forum member bluzman2004...Can I reduce or eliminate the rubber block on top of the spring to lower my rear ride height so I can go back to 8" spring bolts. I have 10" bolts with a steel spring now.
Thanks again to bluzman for a great deal on the spring and fast delivery
Old Feb 10, 2009 | 02:21 PM
White 68's Avatar
White 68
Anybody ?
Old Feb 11, 2009 | 11:56 AM
69autoXr's Avatar
69autoXr
I wouldn't hesitate to reduce it but I wouldn't eliminate it completely.
On mine, I left the pad intact but took out the spring bolt bushings/donuts and replaced them with 1/4" aluminum spacers. I do not drive my car on the street however.
Old Feb 11, 2009 | 12:43 PM
spedaleden's Avatar
spedaleden
I would not touch that block. I'm sure it obsorbs shock to protect the fiberglass spring from cracking.
Just my 2 cents worth
To VBP #420 spring question
