teach me about thermostats
Everything from "Isaac" to "Bubba"
A very simple example concerning flow.
Run a 195° tstat and a good system and it will run around 195°.
Run a 180° tstat and in the same good system it will run around 180°
The only difference in the tstats is that the 195 is designed to restrict more water flow than the 180.
I'm sure everyone can at least agree on that.
So from this you can conclude:
Less flow > higher temperature.
More flow > lower temperature.
Pretty simple.
I don't have a degree in thermal design.
This topic has been beaten to death almost as many times as the "is it OK to restamp your engine" topic. If I put a 220 degree thermo in my car, it will likely run at around 220 somewhere. If I change it out for a 195, my car will run cooler. Change to a 180 and it runs cooler still. Change to a 160 and it still runs around 180. I can put a 140 in there, and it will run around 180. I can take the thermo out, and it will run around 180. I've done this on my cars (well, not the 220 part) and that is how it works in real life.
The temperature rating of a thermostat is the temperature at which is OPENS. Once it OPENS, it's up to the radiator and Fan to keep the temperature DOWN. When the temperature drops below the rating of the thermostat, the thermostat closes (to warm the water UP again), and so on.
REGARDLESS of the temperature rating of the thermostat, you want one designed to FLOW the MOST. Flow does not factor in to the temperature (unless there is an obstruction IMPEDING the flow of water which will make things too hot) It doesn't matter whether you run a 160 or a 190+ degree, they should flow the same. Some of the best designed thermostats (ie. Robertshaw which is also branded as Mr. Gasket) are designed for maximum flow but it has nothing to do with the temperature rating.
Pretty simple.
That’s called “modulating”.
The tstat is just a crude temp based flow control valve. The newer cartridge type can also redirect flow, but that doesn’t apply here.
That is also why there ar different size restricter disks, same purpose, reduce/increase flow, thus temp.
Of course it is limited to the upper and lower limits of the system it is installed in. That’s not the issue.
If you guys think that all thermostats flow the same rate, then what magic makes them different temperatures.
BTW, I’ve been using Rshaw tstats for many, many years and also different pumps and have yet to have any cooling issues.
This is why I suggested that you remove the stat completely and run your car at steady-state at several speeds (ie, 30 mph, 45, 60, 70). Determining the equilibrium temperature for your car's cooling system at each speed can help diagnose what is happening within your cooling system.
[P.S. I'm content with ignoring the other
To the other poster wondering if we even need a thermostat, the answer is most of the time we don't NEED a thermostat. For a variety of reasons, especially when the weather is cold, it is nice to have one, so one is included in the car. Now I said "most of the time", and I can imagine the posts about winters in Alaska and what not, to that I will not respond.
For the curious: I had a 160 stat in my car last year because I had an overtemperature problem. This past Sunday, I replaced it with a stock 180 stat. Why? Because when the system is right, things just work well like that. But, I don't recommend changing thermostats ***** nilly. EVERY time I consider putting a different thermostat in my car, I test it in a pot of hot water with a candy thermometer so that I know at what temperature that specific stat opens. You should try that at home.
Ever heard of wax pellets?
Here is an quote from an SAE publication written by C Burrows and S Tomlinson, Univ Of Bath
Just an idea......
Tom
Have tested dozens and dozens of tstats over the years.
Some of the better ones do open and close gradually and when at their designed temp are not fully open physically so that compensation can be made for an overtemp situation. Wax pellet type tstats do also have a slight problem of overshooting that can result in a slight delayed temperature ocillation. A lot is dependant not only on the wax pellet, but the rate of the spring it must work with.
Also have done quite a bit of a/c, which is a complete other can of BTU's
a 195º t-stat doesn't restrict flow any more or any less than a 180º unit does. The only difference is the temp the units are designed to open at to allow coolant flow thru the system.
Once a t-stat is fully open the coolant flow is the same regardless of it's temp rating.
We got a good thermostat argument going on.
Perhaps the original poster now can get on with solving his cooling system problems.
