Choke crossover blockoff
Old Feb 12, 2009 | 10:36 AM
6t9427's Avatar
6t9427
Default Choke crossover blockoff
I want to block off the choke crossover when I install my new intake manifold can any one give me a part number or where to find stainless block off plates?
They used to come with most performance gaskets sets but I haven't been able to find them.
Old Feb 12, 2009 | 10:55 AM
Mashman's Avatar
Mashman
I just did the same on my 72 - got the gasket with the ports blocked at Advanced Auto Parts.
Since I live in Texas, I thought I could live with the choke issue - but I later reconsidered, so you might want to consider the link below for a divorced to electric choke conversion kit - assuming you are still using carb with a divorced choke.
http://www.carburetion.com/quadrajet.asp
Old Feb 12, 2009 | 02:10 PM
Vette79C3's Avatar
Vette79C3
I'm guessing you already have your intake gaskets but you could also get the gaskets that block off that area as well as using the block off plate. I did this because I wanted as less heat as possible getting near the carb.
Old Feb 12, 2009 | 08:57 PM
Sayfoo's Avatar
Sayfoo
You can make some from a steel can or any scrap metal. Aluminum cans may not last long. But, as said above, I don't recommend it. It doesn't get that cold here in SoCal, but it my car ran like crap for a long time each morning when I blocked them off.
Old Feb 12, 2009 | 09:18 PM
mrvette's Avatar
mrvette
For any car not in the frigid zone of this country....I find that only ONE thing cures that intake crossover....buy some Plaster of Paris, nothing else will do....it's a white powder, mix it up and let it set up in there when you pour it home....as a liquid slightly thinner than toothpaste.....
block off one side with tape, and set the manifold on edge....
it WILL block the hot gasses, ALL gaskets will erode/melt quickly.......
NOW this is only recommended for electric choke carbs....if you have a antiquated hot gas tube thing looping through to heat the carb spring, or a heat choke spring called a 'stove' on the intake....i'ts not a good idea...change over to a internal element electric choke on the carb.....
To Choke crossover blockoff
