Which headers fit the best?
Old Feb 14, 2009 | 11:28 PM
Grumpy 427's Avatar
Grumpy 427
Default Which headers fit the best?
I have an 80 vette Automatic car with a set of 1-5/8 Headman headers. The collector on the drivers side runs into the shifter linkage. The exhaust i took off the car was a basket case and welded up on a severe angle to miss it? What headers will fit without having to make the exhaust an abortion to clear the shifter linkage?
Old Feb 15, 2009 | 06:28 AM
gkull's Avatar
gkull
Many years ago I was under my car and I figured out that the problem with my stock cross member was the sorry *** design of dual exhausts passing through holes being places so near the transmission.
You need to make or buy a pass under cross member.
I had hedman headers that worked fine and then I switched to larger Hooker super comp that also work fine.
http://www.corvetteforum.net/c3/gkull/
Old Feb 15, 2009 | 08:33 AM
Imo Apita's Avatar
Imo Apita
Little thread hijack; GKULL were can I find a Daytona hood like that for my '79?
When I did the home hack job on my exhaust I found out the holes in the cross member are not symmetrical as in on the right side it's like 19' from the frame rail and on the drivers side 26' or so.
Didn't seem to be any rhyme or reason as to why that is.
I have 2' pipe exiting just in front of the rear wheels.
Made quite a bit of difference, can actually break the tires loose if I try now.
Old Feb 15, 2009 | 10:00 AM
gkull's Avatar
gkull
I bought the whole 1981 one piece front end and TT hood from a company in the back of corvette fever magazine many years ago because my vette go hit when I was parked putting gas in it. I thought it look great , had better aerodynamics, and it saved 150 pounds.
Major time. We cut straight down the front fenders of my 79 about 8 inches in front of the doors and removed the old front end
Old Feb 15, 2009 | 10:58 AM
Grumpy 427's Avatar
Grumpy 427
The cross member has nothing to do with this at all.........The collector and tranny **** linkage is no where near the cross member. I guess nobody runs headers here on thier vettes? i will have to phone manufactures next week i guess?
Old Feb 15, 2009 | 11:16 AM
Theiskell's Avatar
Theiskell
Do you have a manual or auto?? I am assuming manual, but FWIW I am running hookers with no problems but mine is an auto 200r4… Reread your post Auto!!
Old Feb 15, 2009 | 11:31 AM
Theiskell's Avatar
Theiskell
I can tell you the competition hookers I have fit better in several places than the Hedmans. I have a friend with Headmans on his 76, he doesn’t have problems with the linkage on the stock tranny, but he did have problems in several other areas.
Old Feb 15, 2009 | 12:53 PM
682XLR8's Avatar
682XLR8
I am using Hooker Comps as well, no issues with the fit
Old Feb 15, 2009 | 01:31 PM
Grumpy 427's Avatar
Grumpy 427
Thank you for the replies. I will call Hooker and see what they have to say.
Old Feb 15, 2009 | 01:44 PM
KevinK's Avatar
KevinK
Another thread hijack.....but what class were you racing in against both a mazda miata, and what looked like a riced out honda S2000?
Old Feb 15, 2009 | 01:59 PM
Scott Marzahl's Avatar
Scott Marzahl
The only issue ever reported with Hedman Elites is they can come close to the idler arm but that is usually a case of worn motor mounts. Are you sure the headers you have on the car or strictly for a Corvette? Could explain a lot if they aren't.
Old Feb 15, 2009 | 02:12 PM
Grumpy 427's Avatar
Grumpy 427
Originally Posted by Scott Marzahl
The only issue ever reported with Hedman Elites si they can come close to the idler arm. Are you sure the headers you have on the car or strictly for a Corvette? Could explain a lot if they aren't.
Yeah i know i am pulling them off today to see if there is a number on the badge or on the flange?
Old Feb 15, 2009 | 02:19 PM
gkull's Avatar
gkull
Those we during open practice on different days before qualifying. SCCA also might put a few faster classes together. The super charged 450 hp racing Honda S-2000's are pretty fast.
Miata's are very slow on lap times and about 50 mph slower on the straights. I do about 155 mph past the flag stand like the picture
Old Feb 15, 2009 | 09:20 PM
Imo Apita's Avatar
Imo Apita
Thanks GKULL, found the company.
Greenwood Corvette:
http://www.greenwoodcorvettes.net/gc3/GTOhood.htm
Old Feb 15, 2009 | 10:02 PM
gkull's Avatar
gkull
Greenwood Corvette:
Not even close
http://www.acivette.com/aci0013m.htm
Old Feb 15, 2009 | 10:17 PM
Imo Apita's Avatar
Imo Apita
Sorry , thread hijack again.
Found that one too:
Old Feb 17, 2009 | 10:07 AM
Grumpy 427's Avatar
Grumpy 427
well i got them off the car last night, and they are the headman 68300. They are supposed to fit my car, made for the car, But are not the right ones. Looks like i will either go to Hooker , or a set of block huggers.
To Which headers fit the best?
Old Feb 20, 2009 | 04:20 PM
Vette80regon's Avatar
Vette80regon
get a set of Stans and forget about it. The Tri-Y's are the shizznet.
Corvette #109Y
http://www.stans-headers.com/tri_y.htm
dyno proven and built VERY well. Cost over $100 more but, it's your vette.
Old Feb 21, 2009 | 07:14 PM
Imo Apita's Avatar
Imo Apita
Call me stupid, can't find prices on Stan's website
How much are the:
http://www.stans-headers.com/Photos/109Y.jpg ?
Old Feb 21, 2009 | 09:17 PM
Grumpy 427's Avatar
Grumpy 427
Wow $500.00 US for a set of headers? Sorry cant do it. I can get a Whole system from Corvette central for $600.00. Besides i am only making 325 HP so i really dont need a set of expensive headers for what i am doing.
