Which headers fit the best?
Old Feb 22, 2009 | 12:24 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Originally Posted by Grumpy 427
well i got them off the car last night, and they are the headman 68300. They are supposed to fit my car, made for the car, But are not the right ones. Looks like i will either go to Hooker , or a set of block huggers.
thanks for that. i was really considering ordering those headers because i'm tired of fighting with the block-huggers. if you go with the hookers, post which ones you get and how they fit. i'll either be doing that or the stan's.
Old Feb 22, 2009 | 08:50 AM
jb78L-82's Avatar
jb78L-82
For what it's worth, I would not bother with full length headers for the street. Shorty headers (not block huggers) fit perfectly, have no road clearance issues, and give much if not more of the benefit of full length headers on the street. I use McJack's shorty headers which are an exact copy dimensionally to the OEM exhaust manifolds in a shorty header form and hook right up to a stock exhaust system. Check out the link below about Sanderson headers for more info:
http://www.sandersonheaders.com/tech_get_technical.php
Old Feb 23, 2009 | 09:30 AM
Grumpy 427's Avatar
Grumpy 427
Which header are you reffering too? They are all tagged as block huggers.
Old Feb 23, 2009 | 01:29 PM
jb78L-82's Avatar
jb78L-82
Traditional block huggers are dimensionally NOT the same as the stock exhaust manifolds. They require a front head pipe that will fit them. Another words you cannot use an OEM type exhaust pipe with them since the header collector is much lower down the side of the block on either side. I use McJack's and, I believe Sanderson's, will hook right up to an OEM exhaust head pipe. There are also clearance issues with traditional block huggers for access to the plugs, not with McJack's, again, they are hand built to mimic the dimensions of the stock exhaust Ram horn manifold but in a shorty header form. Hope that this helps. Google McJacks for a picture.
Old Feb 23, 2009 | 04:03 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
i know its out of your price range but if you want the best set of headers for your vette then this is the place to go.
http://www.mcjackscorvettes.com/headerspage.htm
Old Feb 23, 2009 | 05:21 PM
Grumpy 427's Avatar
Grumpy 427
Sandersons website is a pain? i cant find Vette headers. Oh well back to the Corvette central kit, they have taken all the BS out of it and made a bolt in kit.
Old Feb 23, 2009 | 07:21 PM
Highhat's Avatar
Highhat
Hooker supercomp fit, and worked with both my straight and angled plug heads.
Old Feb 23, 2009 | 07:56 PM
Reggie Dunlop's Avatar
Reggie Dunlop
no need to spend hundreds - the summit and jegs store brand work just as good and fit great. i have used them several times on daily drivers over the last 15 years and the price is a bonus at under a hundred bucks!
Old Feb 23, 2009 | 09:25 PM
spikebot 81's Avatar
spikebot 81
I installed dynamax ceramic coated from summit on a 81 with auto. No problem with fit. Bought dual system from mid america and retro fit to headers. One trip to exhaust shop for custom bend. Total cost for all including hangers and clamps was about $800.
Old Feb 23, 2009 | 11:12 PM
Grumpy 427's Avatar
Grumpy 427
Were they a full length header? or a shorty. Part number would be handy.lolol
Old Feb 24, 2009 | 07:25 AM
jb78L-82's Avatar
jb78L-82
Guys, I agree that there are many many choices for headers and dual exhaust/mufflers. I used Mcjack's headers since I wanted a better exhaust manifold than the OEM Ramhorn, which is quite good on its own but not a header, and a shorty header that would fit easily in the engine compartment, clear all accessories easily, have easy access to plugs/no plug wire issues, would involve zero road clearance issues, AND hook directly to a stock type/OEM dual exhaust with no modifications. Can you mimic the setup for less? Absolutely but not meeting the above criteria. The McJacks headers cost $600, 2.5 in Stainless Steel True duals were $300 (Mid America-I would not recommend since they did not fit right and I had to cut to make them fit right, nothing to do with the headers. They were put on originally with the Ramhorn OEM Exhaust manifolds), and $100/set for the Monza Turbo Mufflers (20 years ago). My total cost: $1,000. Obviously that price would be more today depending on the mufflers, which are so much more expensive now. Just my 2 cents!
Old Feb 24, 2009 | 09:32 AM
fauxrs2's Avatar
fauxrs2
I have the same headers on my car (except with air tubes) in the coated version and they fit fine, apart from the aforementioned idler arm tightness (even with new motor mounts)
Be interesting to see whats going on with your car that they are not fitting right.
Ground clearance is fine, never hit anything with the headers.
Old Feb 24, 2009 | 08:52 PM
  #33
spikebot 81
Grumpy, Just looked up old reciept from summit. 2/18/08 WKL-86008
Yes they are long tube 1 5/8 inch. The headers dont hange down so far so the collecters do not scrap the ground. Infact the lowest part is where the exhaust goes under the diff. I do have 2 spark plug boots that come real close to the tubes but no burnt boots after 4000 miles.
Old Feb 26, 2009 | 12:20 AM
  #34
Alwyn678's Avatar
Alwyn678
Mine fit Quite well, are coated and a GREAT PRICE
