Tar removal
Old Jan 24, 2002 | 01:55 PM
Armstrong's Avatar
Armstrong
Default Tar removal
I have road tar and some kind of asphalt stuff on my car. It will come off with wax if I rub real hard but I'm scared it will scratch the paint. Is there something I can use to get this junk off a little easier. Any ideas will be appreciated. Did the wax deal on a little spot down low and it seems to leave swirl marks. They will be able to be buffed out but man I would hat to see the whole car like that.
Old Jan 24, 2002 | 01:56 PM
terryrudy's Avatar
terryrudy
Default Re: Tar removal (Armstrong)
Got some on my Eclipse and used that "Bug and Tar Remover" from local parts place and it worked VERY well. Was easy to rub crap off and no paint problems whatsoever after about 2 years.
-terry
Old Jan 24, 2002 | 02:04 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Try WD-40 it's safe for paint and it works :cheers:
Old Jan 24, 2002 | 02:07 PM
gearheadz's Avatar
gearheadz
Default Re: Tar removal (yellow 72)
Gojo hand cleaner removes almost anything with no damage to the surface. My roofers even used it to remove some tar they spilled on my patio tile!
Mark
Old Jan 24, 2002 | 02:36 PM
Edzred72's Avatar
Edzred72
Bug and Tar Remover works great.. but it will take the wax off so limit your gentle rubbing to a small area.
WD-40 works great too.
GOJO also works great, BUT...just be be sure NOT to get the abrasive kind!! They make one that has grit in it, and that would be disasterous to paint!!
Old Jan 24, 2002 | 03:19 PM
Casper's Avatar
Casper
Default Re: Tar removal (Silvr77)
I have used diesel for more years than I care to remember. It will take tar off with almost no work at all. Be sure to wash and wax after.
Old Jan 24, 2002 | 05:03 PM
john's '81 mouse's Avatar
john's '81 mouse
All of above will work, and I've used most of them. Main thing is to use a clean soft cloth, and keep changing to a new clean spot on the cloth, don't rug the stuff you take off in one spot, back in on the next location.
Old Jan 24, 2002 | 05:23 PM
Mark69's Avatar
Mark69
Have you tried butter? I haven't tried it on cars, but I know it works really good on surfboards.
Old Jan 24, 2002 | 08:07 PM
PatG's Avatar
PatG
Default Re: Tar removal (terryrudy)
I have used a can of weather strip adhesive remover for years. I had it from when I redid my weather stripping and it does not hurt paint. (but does remove wax)
Old Jan 24, 2002 | 08:33 PM
Armstrong's Avatar
Armstrong
Thanx for all the replies guys. Sounds like I got a few choices to pick from.
To Tar removal
