Hi, I have an 80 with a engine transplant. It's a 350 and I have taken these numbers off the right side of block below front cylinder head-0213ckd. The other number is off the left side of block near bellhousing. It is-3970010. I have done a bit of research and can only determine that it may be a 72-77 block. I was wondering what my timing should be at also for this engine. Thanks for any help, Jay
Icome up with a 1977, ckd=350, 180 HP, at= automatic,ha= high altitude. Not sure what the 0213 means unless it was a replacement block. You might want to ask other 77 owners for engine timing or other info.
CKD 1972
350
tur hydro trans 175 4 F A B X
CKD 1973
350
tur hydro, Calif L48 200 4 A B F X
CKD 1974
350
T350 NB2 - 4 A B F X
CKD 1977
350
a/t, high altitude L L48 180 4 Vette
