New GM Block question
Old Feb 17, 2009 | 12:43 PM
72Shark's Avatar
72Shark
Default New GM Block question
Since I'm in the process of planning for my "rebuild"....been looking at options.
Is the GM Performance 10066034 engine block "ready to go"?? Meaning, any additional machine work needed once it arrives??? This seems like a steal at only $700 for a new block! But, if more machining is required, then the block I have will be the better bet.
Thanks.
Old Feb 18, 2009 | 06:44 AM
BLOCKMAN's Avatar
BLOCKMAN
Thanks.
We have machined alot of thos e Mexican blocks and the bores are finished hone with out a torque plate, The decks are not square on the ones we have seen.
The block you have maybe a better bet
Old Feb 18, 2009 | 09:52 AM
Crash80's Avatar
Crash80
If you are feeling saucy and your 401K is performing well, you can always go this route:
http://www.thetruthaboutcars.com/spo...e/#more-255732
Old Feb 18, 2009 | 10:02 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
good one!
Old Feb 18, 2009 | 10:54 AM
72Shark's Avatar
72Shark
Thanks for the heads up. My block it is......
Old Feb 18, 2009 | 11:44 AM
ED69ray's Avatar
ED69ray
Same here, just decided to build what I already had - even though mine is only a 2 bolt block.
I have heard nothing good about the Mexican cast blocks.
Good luck and post some photos, Ed
Old Feb 18, 2009 | 11:58 AM
timd02's Avatar
timd02
What about the GMPP turn key engines? I am considering what route to go with my engine and am leaning torward the crate engine. Have there been many issues with these and do they use the same block you all are referring to here?
Old Feb 18, 2009 | 12:16 PM
BLOCKMAN's Avatar
BLOCKMAN
Those blocks are a one peice rear seal Mexican casting as well.
Old Feb 18, 2009 | 12:34 PM
timd02's Avatar
timd02
So what is a good/dependable option to go with, both turn key and short block?
Old Feb 18, 2009 | 01:54 PM
Solid LT1's Avatar
Solid LT1
Late model 350 roller cam cores cast in USA are good quality up to the upper 400HP range. I have 3 early 010/020 350 4 bolt blocks with the 2XXX series main caps on them (nodular iron caps for HD truck and LT-1/L-46/L-82 useage.) I'm set for life!
Old Feb 18, 2009 | 03:46 PM
BLOCKMAN's Avatar
BLOCKMAN
Since the Dart SHP block came our we hardly ever see a 010 block, We have used quite a few of the GM blocks and we have had to send a few back do to poor sonic testing.
It depends on your power goals are and how much you want to spend.
Here is a link to the Dart block.
http://speedtalk.com/forum/viewtopic.php?t=12112
Old Feb 18, 2009 | 06:27 PM
63mako's Avatar
63mako
The Dart block would have been my choice if it would have been available when I built my last motor.
To New GM Block question
